2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum P3Cars Vent Gauges
      12-16-2012, 11:51 AM   #1
tp550i
tp550i's Avatar
Drives: 2011 550i Sport
P3Cars Vent Gauges
Installed my P3 Vent gauge this weekend. These were released late last month. Install took about 30 minutes and its as easy as the install video. I purchased the gauge already installed into the vent, that way I can swap back to stock vent if and when I need to.
You'll need a T20 torx bit to remove the vent from the dash. Removing the vent out of the dash is the trickest part, but not difficult. Its plug and play into the OBD port with digital Boost, Vacuum, RPM, Speed, Coolant Temp, Throttle Position, Battery, Air inlet temp and EGT. Also has a 0-60 timer and other features.
I was looking for boost and like having a coolant temp guage. Affordable and works as advertised
I'm anxious to see exactly what kind of boost its now pushing with Dinan S3.
more information here http://www.p3cars.com/catalog/f10/
F10 550i Space Gray | Dinan Stage 5 | Eisenmann Race | ACS springs | 20" Ferric Grey 312 - Michelin PSS
      12-16-2012, 12:48 PM   #2
alextremo
Drives: F10 550i
Looks good, but was hoping for an actual boost gauge rather than just obd2 parameter display.
      12-16-2012, 02:18 PM   #3
tp550i
tp550i's Avatar
It difficult to get a boost tap for an analog gauge on the 550. I recall someone posting about adding one, but it took some fabrication to get a tap.
      12-16-2012, 04:02 PM   #4
dblock2151
Drives: '11 550i Msport DG
Finally! Been inquiring about this since January, and they said it would be ready by summer.
      12-16-2012, 08:39 PM   #5
mercury
Drives: F90 M5 Competition
How did you route the wire down to your obd port? Is it hidden? Thx.
      12-16-2012, 08:43 PM   #6
tp550i
tp550i's Avatar
Yes, the wiring is hidden. Remove the plastic panel on the side of the dash and all wiring and connections are out of sight. Here is a link to the install video.
      01-12-2013, 08:49 PM   #7
tp550i
tp550i's Avatar
anyone else using the P3 or analog boost gauge? I am seeing about 12.2 lbs of boost with Dinan S3. curious what others are seeing.
      01-12-2013, 10:27 PM   #8
leewoods18
Drives: F10 550 M sport
I've reached 10+ psi boost stock reading with p3cars gauges
Site below comparing n63 motor (440hp/450lbs-ft) states max boost is 11.6psi
http://www.**************.com/community/threads/engine-shootout-mercedes-m278-w212-e550-versus-bmw-n63-f10-550i.46889/
2012 550i M Sport Dark Graphite Metallic II Everest Gray Antracite wood 6MT
      01-12-2013, 10:29 PM   #9
leewoods18
      01-12-2013, 10:35 PM   #10
leewoods18
Dinan says 9.8 lbs stock boost
      01-13-2013, 08:01 AM   #11
tp550i
tp550i's Avatar
I seem to remember 9.8 lbs stock for the 2011/12 F10. Sounds like the newer N63 (440hp) boost may have been increased.
      01-13-2013, 10:01 AM   #12
alextremo
Drives: F10 550i
Unfortunately I did not have a way to datalog before I had the flash done, but with Stage 2 it looks like it's closer to 14psi. Since there is no physical boost gauge with the P3 product, your gauge should be displaying the same info as the Bavarian Technic tool that I used here.
Try a 3rd gear pull at WOT from ~3k RPM to near redline and see what the gauge peaks out at.
      01-13-2013, 02:02 PM   #13
tp550i
tp550i's Avatar
max boost was 12.7 lbs on a 3-6500rpm run in 3rd
      01-13-2013, 03:06 PM   #14
alextremo
Drives: F10 550i
Interesting. The article here seems to confirm 9.8 stock and 14psi with dinan, which is what I'm seeing.
http://www.m5board.com/vbulletin/f10...573-lb-ft.html
      01-14-2013, 12:32 PM   #15
tp550i
tp550i's Avatar
I shot a quick email to Scott at Dinan, he stated the 550 should be seeing 13 lbs. I got a message from P3 about another S3 user that claims they have seen 16 lbs on their 550.
I know temps, elevation, etc all come into play to a certain degree but still seems like a wide range.
      01-14-2013, 06:47 PM   #16
alextremo
Drives: F10 550i
Agree. Did they happen to mention any differences between stages? My logs were done on stage 2 tune.
      01-14-2013, 07:00 PM   #17
tp550i
tp550i's Avatar
no but I didn't ask specifically either.
I'll keep experimenting to see what I get at different temps and humidity, not much I can do about elevation, i am basically at sea level.
      09-18-2013, 12:39 AM   #18
Dhu
Drives: 2011 550
Out of curiosity were you able to see more boost out of your p3? Especially when you went to stage 5?
_______________________________________________
Dinan Stage 5 550i, Dinan springs, Dinan Exhaust, Shockware
      09-18-2013, 01:33 AM   #19
ClassM
Drives: BMW 535i msport/M5 E60/M3 E9x
That's pretty sick bro, how much is it? I need one now!
      09-18-2013, 06:44 AM   #20
tp550i
tp550i's Avatar
I am seeing about 13.5lbs of boost. I had some concerns about the accurancy of the P3 digital guage on vacuum and boost readings, including it "locking up". I have installed 2 software upgrades from P3 and it seems to be accurate now. I have a analog boost tap to install and will compare the analog to digital readings soon
      09-18-2013, 09:59 AM   #21
Dhu
Drives: 2011 550
So based on your previous post, you were seeing 12.2 with S3 and 13.5 with S5? Or do you think those were simply measurement/accuracy differences?
Please keep us posted on the analog boost tap vs p3 vent gauge.
      09-21-2013, 04:00 PM   #22
TheRealOrosie
BMW Fan Boy
TheRealOrosie's Avatar
Drives: //M
I have the P3 vent gauge and am Dinan Stage 3. My tune puts out a consistent 1 bar of boost (14.5 psi). Highest reading has been 14.9, but 95% of the time at WOT in 3rd, I will see 1 bar all day long.
