2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 535i 101F01 fault code
      01-29-2023, 12:48 AM   #1
akicked
Drives: F10 535i
Hello everyone, 535i 2011 throws 101F01 "Airmass system plausability: calculated airmasses in the in the air intake system not plausible". It used to trigger CEL now and then, now its always on. Car runs great, just a slightly rough idle. No other fault codes whatsoever. Not great rough running values, which i assume is relevant to the fault code.changed intake manifold gasket , no effect. Any ideas? Thanks
      01-30-2023, 04:50 AM   #2
calswan7145
Drives: 2011 535xi, 2009 328xi
Check for boost leaks. Can run throttle body test with ista too.
      02-03-2023, 07:36 AM   #3
akicked
Drives: F10 535i
Hello and thank you for your reply. I couldnt find throttle body test in ista abl's. Found a test called Electromotive throttle actuator and found no issues. Both measuring sequences got the setpoint value of 5V (sum from both sensors) and there was an audible clicking sound from the engine compartment during the second sequence... is that the test you are reffering to?
      06-20-2023, 05:06 PM   #4
Scottycs19
Drives: 22 X3M, 16 X5 35i
Did you ever get a resolution?
