2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums F10 / F11 5-Series Photos - Video - Media My 2011 F10 535d M Sport Individual (maintenance, repairs, retrofits, mods etc)
      05-16-2022, 11:48 AM   #23
marek555
marek555's Avatar
Estonia
36
Drives: BMW F10 535d, BMW E46 328i
October 2019
I really liked iDrive controller, that comes with NBT. So I decided replace my old CIC controller with newer version.
Here is close comparison between them, NBT version looks much nicer:
NBT controller communicates with ZGW thru K-CAN2 line, in order to controller to work, I installed K-CAN2 wires from ZGW module to the NBT controller:
My CIC controller had 10 pin plug, in which also are 360º camera and PDC connections. So there no other way, I had to connect both controllers to my car, otherwise 360º camera and PDC buttons wont work:
After that, I dismantled CIC controller completely and tucked only electronic part under gear selector:
After ZGW firmware update to latest version, no coding was not needed for NBT controller, it started to work right away.
And here is final result
      06-01-2022, 01:04 PM   #24
marek555
marek555's Avatar
Estonia
36
December 2019
N57 engine has known issue for timing chain stretching out and sometimes even snapping and causing a lot of damage. Recommended change interval for N57/N47 timing chains is max 250 000 km. My car had at least 30 000 km to this mileage, but decided to be safe.
So I bought all the parts needed for this kind of job.
All parts are BMW OE (except oil filter - made by Hengst and injector gasket rings - made by Bosch):
Handed car over to very experienced local guy, who did this job around two days.
I was really glad, that I did not wait anymore with this job, engine timing was already quite off:
Here You can see, how much tensioner is reaching out from his housing:
All the old parts removed and surface cleaned:
All the old scrapped parts:
New improved parts installed:
Oil pan prepared for installation:
