11-08-2019, 12:25 PM | #1 |
Rep 228
Drives: 2022 G20 330E
6WA coding question
Hey, today i have retrofited 6WA to F10, but when i went to flashing procedure i only got cdDeploy checkbox active,all other were greyed out, coded succsesfully, cluster works as it should, but tamper dot is visible (Cluster was virginized, mileage lower than the cars actual).
Main questions: Why were other flashing options greyed out? Why there is tamper dot still visible? Thanks! |
11-10-2019, 02:40 AM | #2 |
Rep 404
Drives: 2008 335i montego blue - 2011
To my knowledge I-step is incorrect that's why those others are greyed out. Did you code the kombi to the car first before flashing it? Red tamper dot could possibly mean cluster wasn't virginized correctly. Pm me and let me know your steps on how you did it. And I can go thru with you which steps you might have missed or is incorrect
01-19-2020, 04:10 PM | #3 | |
Rep 12
01-21-2020, 09:38 AM | #4 |
Rep 2,595
The install itself is plug and play. Actually getting it to work correctly requires some coding work.
2015 BMW 535xi
SSgtC5.00 |
01-28-2020, 11:30 AM | #5 | |||
Rep 404
02-12-2020, 09:38 AM | #7 |
Rep 12
02-12-2020, 09:41 AM | #8 | |
Rep 1,264
You can find a used one and ship to him |
jakesohigian0.00 |
