2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum does a 2014 535d x drive take a special oil?
      08-19-2018, 05:03 PM   #1
CaptainArbano
CaptainArbano's Avatar
Drives: 535d
I have a 2014 535d and I normally order the oil online, but was wondering if it’s just regular 5w30 full synthetic? I went to autozone and the Mobil 1 5w30 full synthetic specifically says “for gasoline engines.”. So I didn’t want to get something that says “for gasoline engines” for a a Diesel engine.
      08-19-2018, 05:56 PM   #2
RetroB
Drives: BMW X3 20d
You'll be fine using the 5W30.
It's what BMW specifies for these engines (the diesel six cylinders) and what I have always used on mine.
      08-20-2018, 03:27 AM   #3
Pierre Louis
Drives: 2016 535d
No, BMW requires at least LL04 which only comes, if in Mobil1 guise, as Mobil1 EXS Formula 5W30. BMW technically requires 0W30 LL12FE for your car, but most seem to agree that 5W30 LL04 will work.
PL
      08-20-2018, 07:41 AM   #4
TEF
Drives: 16 X3 28d/18 540d xdrive
2018 540d xdrive  [0.00]
2016 X3 28d  [0.00]
Having a 535d as well, I've looked into the oil thing too. As far as I know, LL04 is required as it's a low ash content is necessary with the diesel's pollution controls. While a BMW sticker under the hood recommends the use of 0W-30 oil, I not found one with the LL04 rating. The good news, however, is that Walmart sells a Pennzoil synthetic (made from natural gas) with a LL04 rating and the label specifically mentions BMW and diesels. It is a 5W-30 and sell for less than $30 for a 5 quart bottle.
      08-22-2018, 08:26 AM   #5
Pierre Louis
Drives: 2016 535d
LL04 will work, but LL12FE 0W30 is recommended.
      08-22-2018, 11:46 AM   #6
TEF
2016 X3 28d  [0.00]
I think I said that 0W-30 was recommended, but I've yet to see a source for it. Where are you buying yours?
      08-22-2018, 02:00 PM   #7
Dandle
Drives: G05 X5 M50i
0w30 LL04 is the oil the soot burners use in Europe. As someone said above LL04 is the low ash version that's required.
      08-22-2018, 05:33 PM   #8
Pierre Louis
Drives: 2016 535d
Mine still goes to the dealer for complementary service and they haven't used the recommended oil, but put in 5W30 LL04 thus far. The fuel economy with the original fill 0W30 LL12FE was noticeably better.
I live in a relatively hot climate so 5W30 LL04 is probably fine. The dealers are likely one of the few places to get 0W30 LL12FE.
PL
      08-23-2018, 10:33 PM   #9
TEF
2016 X3 28d  [0.00]
Not to be difficult, but I am not sure that BMW USA offers 0W30 for diesels. For example, FCP Euro offers only 5W30 BMW branded oil. At this point, I am getting the free oil changes under warranty, so it's not a urgent, but eventually, I'd like to change my own oil.
When I took delivery of my 535d less than a year ago with less than 5k miles, I am assuming that it came with factory-installed LL12FE oil. However, I really didn't notice a marked difference in the mileage after the first oil change. Presently, I am getting about 40 mpg and 35 mpg for interstate and suburban driving respectively. If 0W30 oil improves on that, I hope it becomes available here in the future.
      08-24-2018, 08:31 PM   #10
Pierre Louis
Drives: 2016 535d
Here is what can be found online for 0W30 LL12FE
Seems to be exceedingly rare in the marketplace. I'm due for service and will try to find out if my local BMW dealer even stocks it.
PL
      09-22-2018, 09:20 PM   #11
markrussell24
markrussell24's Avatar
Drives: 2014 535d xDrive
When my maintenance plan is over, I'll switch to Amsoil 5W-30.
https://www.amsoil.com/lookup/auto-a...rbo/us-volume/
      09-23-2018, 10:49 AM   #12
Pierre Louis
Drives: 2016 535d
PL
My service included 5W30 LL04 oil. Not 0W30 LL12FE.
Tags
engine, oil
