2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Brakes
      03-07-2020, 07:53 PM   #1
zcali925
zcali925's Avatar
Drives: '15 BMW 535i M Sport
Brakes
Ok so there are so many posts. I'm thinking about the power stop crossdrilled z23s front and back. Anyone have experience and/or a thread reference?
Sup
      03-07-2020, 09:45 PM   #2
I've had cross-drilled a couple of times. I would never do it again. Both sets (one was PowerStop) developed micro-cracks at the holes. They are for looks only. I would go with slotted rotors.
      03-07-2020, 10:44 PM   #3
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
what about the cross drilled\slotted one's?
      03-08-2020, 05:32 PM   #4
beegeezy
beegeezy's Avatar
70
Drives: 2013 535i M-Sport
Do you plan on tracking the car? If not, plain rotors/pads will last longer than slotted rotors. If you are driving the car in a way that you need to upgrade the brakes, look into the 550i or 760i brake swaps.
      03-08-2020, 06:48 PM   #5
zcali925
zcali925's Avatar
No not tracking. Just about time to do my brakes (50k), I don't want to spend an arm and a leg. Just upgraded rotors for better stopping power. Already bought the brake lines so I'll do that at the same time. Daily driver with a tendency to push for fun from time to time.
Sup
      03-08-2020, 11:00 PM   #6
That's actually what I had...
      03-11-2020, 12:24 AM   #7
Sylverlee
Drives: White 535i M-Sport, 911 GTS
Do you guys change the rotors even if the thickness is still in spec?
      03-11-2020, 10:30 PM   #8
zcali925
zcali925's Avatar
So would you piece a set together or go off the shelf here. Not a track car, daily driver with a tendency to appropriately have fun
Sup
      03-12-2020, 10:26 PM   #9
sszablya
Drives: 2011 F10 550xi
https://www.summitracing.com/parts/p...el/550i-xdrive
From the Power Stop application guide, these are described as OE 2-piece design, and it seems like the description of all Z23 kits indicates the rotors will be drilled and slotted.
Experience with Power Stop cast 1-piece rotors: 2002 A4, 2007 MDX, both with those rotors. I like I'm just fine!
Power Stop 2-Piece Rotors https://f10.5post.com/forums/showthread.php?t=1699967
I ordered a set, but they're not delivered yet. Pics will go up when they come in.
