04-05-2016, 05:55 PM | #287 |
Rep 2,416
yeah but then again not everyone has a lap top. i think bluetooth will be best.
2011 550i RWD 60-130 7.35
04-06-2016, 03:51 PM | #288 |
Rep 99
Found one of the factory clamps a little loose on the passenger side that connects the air tube to the plastic piece that goes to the turbo, thinking that's where the vacuum leak might of been. hooked the chip back up, so far so good. Will clear the codes tonight and see what happens next.
Also, I took some Extreme Weather HVAC Foil Tape and wrapped the flex tubes in the back. I don't know if it'll help, but it definitely cant hurt. Gets pretty hot back there, a few layers of foil gotta at least keep a little heat out. |
04-06-2016, 04:57 PM | #289 | |
Rep 118
Drives: BMW F80 M3
04-06-2016, 07:54 PM | #290 |
Rep 2,416
From me that's the whole intake maf hosing is the part of it.
04-07-2016, 12:57 AM | #291 |
Rep 2,416
There is an update for the intake i think i messaged everyone that purchased, if you didn't get it you will.
04-07-2016, 09:09 AM | #292 | |
General K
46
Rep 172
-K Last edited by General_Keller; 04-07-2016 at 09:40 AM.. |
04-07-2016, 12:46 PM | #294 |
Rep 118
Drives: BMW F80 M3
04-07-2016, 12:50 PM | #295 |
Rep 118
Drives: BMW F80 M3
04-07-2016, 01:07 PM | #296 |
Rep 2,416
It is still covered under the hood, unless you're submerged under water you will be fine, just don't go out racing in the rain. It is very hard to Dyno an intake you would need giant Fans to create high speed winds in a closed chamber. Best way is to go to the track and compare your previous results. I am the still the only N63 to get in to 11 seconds and best of 11.8
04-07-2016, 01:26 PM | #297 | |
Rep 118
Drives: BMW F80 M3
We'll talk about asap. |
04-09-2016, 08:48 PM | #299 |
Rep 7
I saw you put up on the website to get the xseries auto. When ahead and ordered already just to be on the safe side. Getting my car tuned here locally once it breaks in nicely. Or would it be better to install and then get it tuned and let them miss with the error codes?
04-09-2016, 09:25 PM | #300 | |
Rep 2,416
04-10-2016, 12:15 AM | #301 |
Rep 7
Thats a good question. I'll call on monday and ask. I told them it was for a 2011 550i said I would make more power and run better than using the bms tune. Thanks will be defiantly looking out for it!!!
04-11-2016, 11:27 AM | #302 | |
General K
46
Rep 172
-K |
04-11-2016, 01:10 PM | #303 |
Rep 2,416
No one can crack that old piece of crap ECU, it has 2 mobos on top of each other so you cannot even drill in, to tap in to it.
04-12-2016, 12:54 PM | #304 |
General K
46
Rep 172
You ever think about going with Dinan Intercoolers? Would there be clearance around the intake with a little larger intercoolers? You know of any other companies making intercoolers for n63?
04-12-2016, 03:24 PM | #305 |
Rep 2,416
no issues with clearance, no one else makes them 2 much work.
04-13-2016, 07:14 PM | #307 |
Rep 2,416
Replied via PM
