2010 2011 BMW 5 Series Forum F10 F10 550i Vacuum CCV/PCV Question |
09-21-2017, 11:31 AM | #1 |
Rep 659
Testing my vaccum; On a turbocharged car, when we remove the oil filler cap, is there supposed to be a slight suction which confirms the CCV is functioning properly. I know Naturally Aspirated engines have a slight suction, but I wasn't sure about turbocharged engines.
The reason I ask is because I removed my oil filler cap and placed a rubber glove over the oil filler opening and the glove filled up a little. So Im wondering if my CCV/PCV valves needs to be replaced on my F10 550i??? |
09-21-2017, 01:57 PM | #2 | |
Rep 2,416
2011 550i RWD 60-130 7.35
09-21-2017, 03:29 PM | #3 |
Rep 659
09-29-2017, 03:13 AM | #4 |
Rep 16
They don't seem to have appreciable vacuum like the NA engines. Mine has almost none at all. If your oil consumption is OK and no leaks through your seals then I would guess there us nothing to worry about.
As per ISTA....... Ambient pressure is 0.95bar, very slight vacuum 0.8 bar, pressure control valve faulty 1.07 bar, clogged system or kinked vent line Atmospheric pressure is 1.01bars, so I am interpreting this to mean that if you have +pressure then system is clogged! Not sure what the solution is for positive pressure rather than excessive negative pressure. |
