2010 2011 BMW 5 Series Forum F10 Lci msport bumper to non lci |
04-17-2017, 06:27 PM | #1 |
Rep 767
Hey guys I want to buy an msport bumper for my non m sport bumper however the car the m sport bumper is coming from is LCI and my car isn't LCI would it be completely compatible????
04-18-2017, 04:38 AM | #3 |
Rep 6,308
I believe compatible as grilles and hood lines are the same. however if I were you I would just call BMW dealership and ask. there could be parts that are not interchangeable / i.e. LED fogs for instance.
F30.F11.E86.E90.E90.E36 |
04-18-2017, 07:44 AM | #4 |
Rep 34
To my knowledge, the only difference between pre-LCI and LCI m-sport bumpers are the position of the fog lights.
Pre-LCI fogs are positioned on the outer edges LCI fogs are positioned in the middle |
Bklynjoker84.50 |
04-18-2017, 08:03 AM | #5 |
Rep 878
Suppose a non-LCI M-Sport owner wanted to install those LCI fog surrounds on their car without changing anything else, is it plug n' play by just swapping the surrounds?
-WJV
04-18-2017, 08:41 AM | #6 |
Rep 1,214
No, the brackets that mount the fog lamps are integral to the front bumper cover and not designed to be swapped over.
Quicksilv3r233.50 |
05-02-2017, 03:24 PM | #7 |
Rep 34
The only differences in the bumpers are, as stated above, the fog lights (only LED) and the grills. The fog lights are attached to the bumper itself. If your car is not LCI the invest in the LED Fog lights would be nearly the same as you would spend on the bumper itself. Solution here is the M550d grills, which have no fog wholes. The grills itself are three times more expensive than the regular ones. Another solution would be to get a custom cut grill, again with no fog lights and disable the warm/cold monitoring to avoid iDrive error messages.
