2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum M5 Sway bar fitment problem on a NON Msport 535
      08-11-2014, 05:00 PM   #1
twelve535i
twelve535i's Avatar
Drives: 2015 X5 35i M Sport
I took my 2012 535i X drive (non M-sport) to the shop to get a front M5 sway bar and a rear 550d sway bar installed.
The rear bar was a perfect fit.
The mechanic tried to fit the front bar, but said the brushing wouldn't fit properly because it didn't sit flush against the frame of the car (I think its the frame that the brushing is screwed into??)
He pointed out that the brushing so too close to curved portion of the bar. Does that matter?
Could he just of shifted the brushing?
I tried to search the forum, but it appears all the 535's with M5 bars installed are M Sports, so I'm wondering if there are any non Msport owners who have successfully installed the bar.
      08-12-2014, 01:05 PM   #2
Super6
Drives: 2012 535xi, 2014 640i
It should fit the 535xi with no issues. Mine fit perfectly and its a non M-sport.
http://f10.5post.com/forums/showthread.php?t=799827
      08-12-2014, 01:22 PM   #3
twelve535i
twelve535i's Avatar
Thank you sir. I will give it another try.
      08-12-2014, 02:38 PM   #4
Alan l.
Alan l.'s Avatar
5453
Just want to make sure your M5 FSB came with new bushings right?
      08-12-2014, 03:05 PM   #5
twelve535i
twelve535i's Avatar
Yep. Still said it didn't fit.
      08-12-2014, 04:24 PM   #6
Alan l.
Alan l.'s Avatar
5453
Here is a pic of my stock FSB on a 2013 535xi Msport.
Does yours look the same as mine?
      08-12-2014, 04:38 PM   #7
twelve535i
twelve535i's Avatar
I can't remember. I'm gonna go back to New Hope and ask for Alex. Lets hope 2nd time is the charm.
      08-12-2014, 05:36 PM   #8
twelve535i
twelve535i's Avatar
BTW Alan, what Am I looking at in that picture?
      08-12-2014, 06:17 PM   #9
geminiys
Drives: 2013, 535XI & 2005 M3
Sorry for been off topic here but I have a question:
What is the difference between the M5 Sway Bar and stock that makes the handling so much better? I understand not having one and putting one in vs. replacing it?
I have 2013 535xi non-MSport and wondering if it will fit on mine. Please update with your project.
Thank you
2013, 535 XDrive, 112k miles
1997, 328is, 335k miles - Retired
1998, ML320, 200k miles - Sold
2018, Q5, 100 miles
2005, XC70 AWD, 160k miles
      08-13-2014, 02:02 AM   #10
Boss330
Boss330's Avatar
Not sure what your mechanic means by not sitting flush against the frame?
Is there a gap between the bush and the frame or is the bush to large?
Remember that there is a piece of metal that sits between the frame and the bush (it's clearly visible in Alan I's photo, just on top of the foremost red circle). This piece of metal holds the bushing inside the U-shaped metal tab that surrounds the bushing. Without this metal tab the bushing will have a lot of free play and won't sit flush against the frame.
But a bit strange if your mechanic didn't notice these tabs when he pulled out the original sway bar...
      08-13-2014, 12:20 PM   #11
Antique-ace
Antique-ace's Avatar
Drives: 2022 M240i xDrive
Is he trying to install the front sway bar with the suspension loaded or unloaded? The front M5 sway bar does not fit properly unless (front) the suspension is loaded (i.e., the weight of the car is on the wheels).
      08-13-2014, 02:43 PM   #12
Boss330
Boss330's Avatar
I had no problems fitting a M5 CP front sway bar with both front wheels in the air...
      08-13-2014, 03:13 PM   #13
Antique-ace
Congratulations!
Others have reported having problems fitting the front M5 sway bar with the suspension unloaded. Start reading at post #281...
http://www.bimmerfest.com/forums/sho...s+sway&page=12
I installed mine with the suspension loaded.
      08-13-2014, 03:20 PM   #14
Boss330
Boss330's Avatar
Congratulations!
If one side is loaded and the other not, then it surely won't fit.
But, at least on my car, the two sides matched up without any issues at all.
The sway bar is fully moveable up and down before attaching it to the links on either side. The links on each side is also in the exact same height when both wheels are unloaded (or loaded on a level surface).
But I don't think this is the issue the mechanic was having. The OP said the bushings wasn't sitting flush against the frame.
      08-14-2014, 08:07 AM   #15
Antique-ace
Okay, then all I can think of is that the OP has the wrong part. The correct PN is 31352284460 (the correct bushings and brackets are included on the sway bar)
      08-14-2014, 01:43 PM   #16
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
Thank you
M5 sways are thicker, so they're more rigid and keeps the car from rolling so much when driving around corners.
      08-14-2014, 07:50 PM   #17
twelve535i
twelve535i's Avatar
You may be right. I will check later when I get home.
      08-14-2014, 11:51 PM   #18
twelve535i
twelve535i's Avatar
Looks right to me
      08-15-2014, 11:32 AM   #19
Antique-ace
Yes, that looks correct. It should fit perfectly.
2022 M240i xDrive | Thundernight, Black Vernasca w/Blue Stitching | Premium Package, Driving Assistance, ZTK, Remote Start, Drive Recorder, Shadowline | Dinan CAI | AA Downpipe |
Turner Skid Plate |
SOLD: 2011 550i xDrive, 1995 M3.
