2010 2011 BMW 5 Series Forum F10 Downpipe on N63 Loses Power? |
04-24-2018, 04:12 PM | #1 |
Rep 46
Drives: 2012 550xi
Hi Guys, It is pretty embarrassing...
I just raced my friend in his STOCK G37 Couple AT running at "330hp" I am running a tune with catless downpipes on my N63 AT, running at "500hp" Both cars weigh roughly the same... BMW @ 3714 lb, and G37 @ 3710 lb. We did a roll race and after 2nd gear he pulled on me. Some people are saying that Catless downpipes actually lose power, there was a thread but has anyone else / can anyone else back this up? My car isn't throwing any codes, and with my catless dp I feel heavy boost / torque gains Any suggestions? Aside from "learn how to drive" I haven't compared it to my own R35, but I had seen a video of a JB4 550i racing a R35 GTR and it kept up with it.. Not sure what is wrong
2013 Nissan GTR, 2012 BMW 550xi, 2011 Audi S4, 2015 Ford Mustang Eco Boost, 2002 Audi A4
ig: @lordjlam |
04-24-2018, 04:24 PM | #2 |
Rep 167
Do you have a JB4 Bluetooth device to actually see if your Map/boost is where its supposed to be? I wouldn't think DP would make you lose power.
04-24-2018, 05:00 PM | #3 | |
Rep 46
Drives: 2012 550xi
Sorry, I should have clarified. I am running a different tune(not jb4), that is supposed to be putting out more power than the JB4 and the company who has done my tune has several dyno data for their power claims. I agree about DP losing power, and this is what I have read on forums for the N63 Platform.
ig: @lordjlam |
04-24-2018, 06:03 PM | #4 | |
Rep 2,416
2011 550i RWD 60-130 7.35
04-25-2018, 12:43 AM | #5 | |
Rep 659
check for boost leaks also.... |
04-25-2018, 09:45 AM | #8 |
Rep 659
I had a tuned/e85 '15 Subaru WRX, a tuned Mazadaspeed 3 and a FBO 370Z Nismo pull on me after 90mph. I made a post awhile back regarding why my turbos sounded like a high pitched blower at high rpm and the top end was severly weak. There was no power after 5k, I had to short shift just to keep power on.
I checked for vaccum leaks and found a cracked/detached crankcase breather hose on the passenger bank. I R&R'd that and still had a loss of power. Went even deeper on inspection, checking the vaccum lines and found a completely severed driver side bank turbo wastegate hose that runs from the turbo wastegate up and down under the alternator to the vaccum assembly behind the passenger watercooler/intercooler. Replaced that hose and now I have full power, turbos comeon much sooner and the turbos do not whine at high rpms anymore. Pulled a '16 392 Charger on the highway, put several cars on a '15+ Subaru STI RA and a modded '16+ 5.0 couldnt reel me in on the highway. Check all your vaccum lines Last edited by 535_BiTurbo; 04-25-2018 at 09:54 AM.. |
04-25-2018, 10:36 AM | #9 | |
Rep 487
He should be whopping him from a roll or dig especially when he has more power and torque stock for stock unless he is having a boost leak. The OP should get his car smoke test and dynoed. http://www.bimmerfest.com/forums/arc.../t-746487.html |
lordjlam19.50 |
04-25-2018, 12:58 PM | #10 |
Rep 46
Drives: 2012 550xi
Already booked an appointment with my shop next week Monday. Thanks guys. Just wanted to figure it out / get an idea what may be the cause.. Pretty damn embarrassing to lose to that. It's not throwing any codes either, Would any of the issues 535 is explaining throw codes?
ig: @lordjlam |
04-25-2018, 02:15 PM | #11 | |
Rep 659
04-26-2018, 09:02 AM | #12 | |
Rep 697
N63 runs hot, causing premature deterioration of rubber parts. |
04-26-2018, 08:06 PM | #13 |
Rep 738
Lol my stock 550 was faster than my old G37 by quite a lot, and after DPs and tune I was hauling ass into the low 12s
2011 550i
2013 M5 2014 M5 CP 2016 550i |
04-26-2018, 08:08 PM | #14 |
Rep 46
Drives: 2012 550xi
So turns out, I am misfiring in 7/8th cylinder
Theyre gonna change my coil packs on Monday and I also have a broken Breather hose. Im hoping that should be the cause of low power.. or do you guys think there could even be anything else or is it the tune?
ig: @lordjlam |
04-27-2018, 07:58 AM | #15 | |
Rep 697
You can't suspect a tune when your car has mechanical issues. |
04-27-2018, 10:52 AM | #16 | ||
Rep 46
Drives: 2012 550xi
Im just worried as 535 said, the breather hose wasn't even causing his issue.
ig: @lordjlam |
04-27-2018, 01:58 PM | #17 |
Rep 697
Fix these problems and monitor boost pressure. Also check for BMW codes. I use carly app for this. These are not much worst than other 400hp cars :-)
I drove mine 151 mph no issues, ran Mustang GT (such a close run), Charger R/T (close run) on different days. Car has been consistent with performance so far. I will be tuning it next week to be more "competitive". Seems like many newer cars have ~ 400hp these days... |
08-04-2020, 09:35 PM | #18 |
Rep 97
LOL. your 2012 BMW 550i xi weighs 4500lbs...not 3714. So close. Where did you even get that number??
2011 e90 n55- fully upgraded fuel and air system. Hellcats dont like me
2012 e70 n63- m package, ESS flash tune, x5m bumper and megan racing quad exhaust |
