2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Installed M5 Exhaust this weekend
      04-12-2017, 03:14 PM   #23
txoid
Drives: f10
Any update? Droning, valve config . . .
      04-12-2017, 06:04 PM   #24
xxpanipuri
Drives: 550i
btw here's the part # (in this thread) for the cross members/nuts/bushings
http://f10.5post.com/forums/showthread.php?t=963730
      04-26-2017, 09:19 PM   #25
txoid
Drives: f10
So I installed M6 mufflers and the sounds is great. I'm currently working on something that will an a vacuum option to the rear (535i don't have this). Along with the OEM valve I hope to complete in 2 weeks. I'll keep you posted.
If anybody know the pigtail/harness for the OEM valve, please let me know.
      04-26-2017, 11:44 PM   #26
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
Do you need this if you only installed the mufflers from axle back?
      04-27-2017, 05:37 AM   #27
MavRick
MavRick's Avatar
688
Drives: My Wife's M
misleading thread title.... M5 mufflers.
      04-27-2017, 03:25 PM   #28
txoid
Drives: f10
AMTF10 You don't need those items if your just installing the mufflers from the axle back.
The M6 and M5 mufflers are close enough to be the same. You will need to transition from 2.5 to 3" piping and modify hangers.
AMT92389.50
      04-27-2017, 03:33 PM   #29
ndinh
Drives: 640i GC, X5
Just fyi, this is what Jason from exhaustmeister sent me awhile back. I'm too lazy to go through the process but it's definitely possible.
'If the mounts are present, I see no reason you couldn't add the vacuum actuated valves to each side. That would be a cheap junkyard part. The next step would be routing a vacuum line from the engine to the trunk space to interconnect to the Pierburg Vacuum Switch (cheap to buy). Then you would need to connect the muffler valve vacuum lines to the Pierburg Switch. After that you could install an ExhaustMeister. Since your car lacks the switch from the factory, you would need to run a +12 volt supply to the ExhaustMeister. That part is easy since the battery is in the trunk.'
It's a little bit of work but sounds possible. If you go that route and get all of the components in place, you would just need to cut the male connector off of the ExhaustMeister harness and direct wire to the battery in the trunk.
      04-27-2017, 03:56 PM   #30
txoid
Drives: f10
I am running the vacuum from the engine bay to the rear. I found the vacuum source from a 525i. Testing the vacuum this weekend.
Do you have the pigtail/harness for the Pierburg Vacuum Switch?
I also need to know where this goes to. The switch is cheap and easy to buy.
      04-28-2017, 03:21 PM   #31
The_M6
The_M6's Avatar
Drives: 2013 M6
Sounds damn good!
Project Gamma Intakes / Project Gamma Catless Downpipes / Muffler Delete / DME Stage II Tune / H&R Springs
      05-04-2017, 12:00 PM   #32
txoid
Drives: f10
Finally got to my testing and figured out a way to make the quad exhaust with valves work on a 535i.
I'll start a new thread with the details in the next couple of days.
ey2001310.00
      05-10-2017, 10:10 AM   #33
spielnicht
Petrolhead
spielnicht's Avatar
440
This picture clarifies (for me at least) why BMW moved the Comfort Access and TPMS modules on the M5. That proximity to the tips will surely damage them in no time.
      05-10-2017, 11:13 AM   #34
ndinh
Drives: 640i GC, X5
Thanks for the pic. I've always wondered where it was.
      07-20-2017, 11:24 PM   #35
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
I just picked up a set of m5 mufflers.... could some explain why ppl go X and J piping? Couldnt i just get the mufflers welded on like an axle back? I have 535i
      07-21-2017, 09:26 AM   #36
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
From what I've read on here, J/X pipes are use to reduce drone at low rpms. I currently have M5 mufflers and there is a little drone at low rpms but it doesn't really bother me.
The mufflers them selves will be axle back.
      07-21-2017, 09:28 AM   #37
ey2001
ey2001's Avatar
310
Do you just have the muffler on without the j or the x?
