2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 2011 535i bucking feeling
      09-25-2016, 12:56 AM   #1
izaazk
Drives: 2013 335i
So I installed my JB4 the other night and it's made my bucking more noticeable
If I try to rev out the car it feels like it doesn't want to be revved and just bucks in a sense
No CEL this was there before JB4 but now more noticeable ...
Map 1
I haven't changed plugs yet but any idea what it could be?
      09-25-2016, 08:47 AM   #2
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
How many miles on the plugs? It could be spark blowout. Hard to say anything for certain though from your description.
      09-25-2016, 10:24 AM   #3
izaazk
Drives: 2013 335i
I don't know for sure I bought new plugs will install them today
      09-25-2016, 08:27 PM   #4
rayhwc
Drives: F11 535i
Possibly one or more of the ignition coils? I had initially experienced vibration on my car at highway speeds, then engine misfire on heavy throttle. Turns out one ignition coil was bad at 75k km.
      05-05-2017, 06:37 PM   #5
eaglecomm
Drives: 2011 535i 6MT & 2015 M6 GC CP
2011 BMW 535i  [10.00]
izaazk Any updates on your bucking? I feel like I have something similar and the JB4 and SB has made it more noticeable. I have changed the plugs and no difference. I might have to buy a single coil and go through the rounds and see if replacing any of them helps.
I have a manual so I thought it was me getting used to the clutch and gas since this car is new to me. But I can tell that my gas pedal is consistent when the bucking/stuttering happens.
      05-06-2017, 12:23 AM   #6
Johnsaidgo
Drives: 2011 535i
I installed JB4 and got a misfire in cylinder 2. Changing plugs tomorrow and will update on if it fixed the problem. if it doesnt, Ill definitely be doing the coil replacement. This has been super inconvenient haha I regret putting in the JB4. I have a manual too
      05-06-2017, 10:55 AM   #7
5soko
5soko's Avatar
333
Drives: M5
How many miles on the car
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
      05-06-2017, 11:57 AM   #8
Johnsaidgo
Drives: 2011 535i
37,000
      05-06-2017, 10:17 PM   #9
Johnsaidgo
Drives: 2011 535i
Changed spark plugs, none had signs of failure. Car has codes cleared and no CEL. Drove it for around 80 miles now with no hiccups.
      05-07-2017, 01:23 PM   #10
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
If you have problems with a tune after plugs tap them down to .22
This helps prevent spark blow out due to running higher than stock boost. If it persists clean you MAF and MAP sensor. If that doesn't resolve your problem then invest into ignition coils. If all that doesn't resolve your problem then look at hpfp and injectors.
If all fails then just get the F80 M3
IG: @bmwdoubles
      05-08-2017, 12:19 PM   #11
eaglecomm
I'm at 81k miles. Problem is that I don't have any history with the car. So I am proactively working to replace what 'might' not have been done over time, anyways.
      05-08-2017, 08:12 PM   #12
5soko
5soko's Avatar
333
Drives: M5
I got ya, the full ignition system is a good place to start.. Coils and plugs. Esp when modded.
      05-08-2017, 10:06 PM   #13
eaglecomm
Yeah, I'm hoping its the coils. Injectors are an expensive exploratory venture.
      05-09-2017, 07:46 AM   #14
5soko
5soko's Avatar
333
Drives: M5
Injectors from bosch are about 130 each.. but do require ista to code in the specific injector number into the dme..
The injector removal tool is available on ebay for about 30 bucks from china..
Not a hard diy, pretty straight forward. But i haven't seen many injector failures on the N55..
      05-09-2017, 09:15 AM   #15
eaglecomm
Got it. Thanks. I think I will put up a thread and explain what issues I am getting and see if anyone has had similarities. They seem too specific and reproducible.
      05-09-2017, 09:16 AM   #16
5soko
5soko's Avatar
333
Drives: M5
And to be clear, no codes when scanning the car?
      05-09-2017, 09:38 AM   #17
eaglecomm
Correct, no codes/CEL from OBD Reader/JB4 scan.
      05-09-2017, 10:32 AM   #18
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Are you getting bad MPG? O2 sensors can start going bad without throwing codes and the outcome is poor performance, loss of MPG, rough idle and in worse cases misfires. 1 misfire and then you'll get codes
IG: @bmwdoubles
      05-09-2017, 12:41 PM   #19
eaglecomm
Reported with the computer @ ~25MPG. I haven't manually logged it yet though.
      05-16-2017, 10:28 AM   #20
addy27
Drives: F10 550i
I have an n63 and was getting the stuttering/bucking and it got worse, the car started throwing the dreaded Drivetrain Malfunction error and the engine would start running rough. The reason is that the DME will turn off a cylinder that is not performing at the same level and so that threw the whole thing off balance by running only 7 cylinders. Anyways, after two trips to the dealer and replacing coils and injector on the suspected cylinder, they nailed it down to one particular spark plug. They had tried swapping it to a different cylinder first and it worked on that cylinder so they swapped it back. But once they replaced the cool, the stuttering got worse. Once the spark plug was replaced, I'm not getting the stuttering/bucking or drivetrain malfunctions and I've tried to push the car too. So my recommendation would be spark plugs first.
