2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Accidentally clicked on "Code Default Values" in KOMBI... I'm Dead
      12-05-2017, 10:03 AM   #1
AlpineWhite_F10
AlpineWhite_F10's Avatar
17
Drives: 2013 535i M Sport
Hello everyone, today i had accidentally clicked on "Code Default Values" in KOMBI module on my 2012 F10 535i... on idrive showed few errors and changed many things changed brake pads to worn status...
on iDrive writed SOS is not working... self leveling not working, made few changes on instrument cluster, i have 6WA KOMBI, removed transmission position indicator, removed Efficient Dynamics blue stripe on fuel consumption indicator, when changing driving modes (from comfort to sport) doesn't shows on cluster... Head Up Display changed color, it have light pink color...
So.. what can I do? I'm very scared I know that I am in cavil
Help me please
      12-05-2017, 12:01 PM   #2
snj1013
Drives: 2011 528i
I believe if you VO code KOMBI, you should be back in business. Of course, any of your FDL coding changes will be wiped out and you would have to re-code those changes.
      12-05-2017, 03:13 PM   #3
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Not a expert here sounds like you have to take car to dealer reload of software????
      12-05-2017, 05:31 PM   #4
zugellos
Drives: 535i M-Sport
That's right. The car is "bricked". He'll have to take in to the dealer. Same thing happened to some friends of mine.
I tell you...that Esys would be more welcoming if that darn button is not available. I would play around more with coding then.
      12-05-2017, 07:06 PM   #5
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
new version of the e-sys launcher from tokenmaster has the button text saying never click this or something like that so you don't click on the button.
      12-05-2017, 08:09 PM   #6
BlackWidow
Drives: M5
Are you under warranty?
If you know what you’re doing, inject CAFD and VO Code Kombi ECU. That will fix the problem.
      12-06-2017, 10:54 AM   #7
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
from what I hear I takes long long time for dealer to install
      12-09-2017, 02:18 PM   #8
mness
Drives: 2013 535iM
I doubt a dealer will fix for free what the owner mucked up themselves. Warranty is for manufacturing defects.
Also, check the bimmerfest coding forum and seek out ShawnSheridan or Almaretto.
2013 535i M-Sport: Carbon Black with Oyster/Black Dakota, SAT, Driver Assistance Pkg, Premium Pkg, Multi-Contour Heated Seats, Navigation, H/K stereo. Michelin Pilot Sport 4S non-runflats, M5 grille, Painted reflectors from IND.
      12-09-2017, 04:08 PM   #9
BlackWidow
Drives: M5
Dealer will fix it if it’s under warranty. I’ve seen it done before, come up with some excuse that you woke up and the car isn’t working right. They’ll easily determine its a software issue and reflash the car.
Or OP could do what I suggested in the previous post and be back to normal. Which is essentially the process in ESYS to reflash the ECU he coded default values to.
      12-10-2017, 09:04 AM   #10
babaikram
M6GCComp, Porsche Cayman S PDK, Peug 208 GT1 BPS
Drives: .
Well what a backup mode. That exists on Bimmercode.
