2010 2011 BMW 5 Series Forum F10 Accidentally clicked on "Code Default Values" in KOMBI... I'm Dead |
12-05-2017, 10:03 AM | #1 |
Rep 34
Hello everyone, today i had accidentally clicked on "Code Default Values" in KOMBI module on my 2012 F10 535i... on idrive showed few errors and changed many things changed brake pads to worn status...
on iDrive writed SOS is not working... self leveling not working, made few changes on instrument cluster, i have 6WA KOMBI, removed transmission position indicator, removed Efficient Dynamics blue stripe on fuel consumption indicator, when changing driving modes (from comfort to sport) doesn't shows on cluster... Head Up Display changed color, it have light pink color... So.. what can I do? I'm very scared I know that I am in cavil Help me please |
12-05-2017, 12:01 PM | #2 |
Rep 937
I believe if you VO code KOMBI, you should be back in business. Of course, any of your FDL coding changes will be wiped out and you would have to re-code those changes.
12-05-2017, 05:31 PM | #4 | |
Rep 291
I tell you...that Esys would be more welcoming if that darn button is not available. I would play around more with coding then. |
12-05-2017, 07:06 PM | #5 | ||
Rep 357
Drives: 19' M2C
EL Jeffe 5611.50 |
12-06-2017, 10:54 AM | #7 | |
Rep 1,254
from what I hear I takes long long time for dealer to install
12-09-2017, 02:18 PM | #8 | |
Rep 214
Also, check the bimmerfest coding forum and seek out ShawnSheridan or Almaretto.
2013 535i M-Sport: Carbon Black with Oyster/Black Dakota, SAT, Driver Assistance Pkg, Premium Pkg, Multi-Contour Heated Seats, Navigation, H/K stereo. Michelin Pilot Sport 4S non-runflats, M5 grille, Painted reflectors from IND.
12-09-2017, 04:08 PM | #9 | |
Rep 317
Or OP could do what I suggested in the previous post and be back to normal. Which is essentially the process in ESYS to reflash the ECU he coded default values to. |
