2010 2011 BMW 5 Series Forum F10 Can I add a Powered Subwoofer to a 550i??? |
11-09-2013, 05:33 PM | #1 |
Rep 781
Is it easy to add a powered subwoofer to a 2013 550i? Does the stock stereo (which I have) have a subwoofer output? If not, how would I get a signal? Would I need a crossover?
Any input would be great. Thanks |
11-10-2013, 05:31 AM | #2 |
Rep 359
11-10-2013, 08:23 AM | #3 | |
Rep 12,996
- Premium or B&O = OEM amp woofer high level outputs peak at about 30-35V. Tap OEM amp woofer outputs with an Audiocontrol LC2i (40V max input) active LOC. LC2i provides the low level inputs to the sub amp. Remote turn on signal is found at pin 13 at the rear of iDrive unit. No remote signal can be generated by the LC2i and the OEM amp. - HiFi system = tap OEM woofer outputs with any passive LOC of 8V/50W max input. Remote turn on signal is located at pin 10 of the OEM amp connector. |
11-10-2013, 09:14 AM | #4 | |
Rep 619
11-10-2013, 09:31 AM | #5 | |
Rep 781
11-10-2013, 11:32 AM | #6 |
Rep 12,996
Send me a PM with the last 7-digits of your VIN and I will tell you what you need in detail...
02-23-2019, 03:18 PM | #7 | |
Rep 492
F10 M5 CP.
Previous: F31 340i, E90 335i SE, E87 130i, F10 550i, E92 335i, E61 550i, E90 335iM, E87 130i, E87 118d, Z4M, Z4 3.0i SMG, E46 330D, Z3M, Z3 3.0i, Z3 3.0i (USDM) |
