2010 2011 BMW 5 Series Forum F10 25k miles on my 2014 550i and SES Light - N63TU |
08-10-2017, 12:14 PM | #1 |
Rep 1,154
Codes show p0171 (bad MAF)
Other symptoms. oil at the top of engine (under engine cover) Squeaking sound on cold start Rough idle (when engine is warm or cold) Apparently there is a recall on the Crank Case Vent Hose. All of the above issues could be related to that (says my SA) Will update this thread once i get the car back and more info. Apparently this is a new recall, as I had the oil changed (mid service) in May. Something to look into for you guys who haven't had this issue yet. For those of you who have had this issue please chime in. Check the thread below for more info. http://www.6post.com/forums/showthread.php?t=1250199 |
08-12-2017, 11:39 AM | #2 | |
Rep 112
Most likely your idle will smooth out once you get a new MAF sensor. However, all of your symptoms are absolutely unacceptable given your mileage. Are you sure that the oil on top of your engine was not spilled during a top -up? |
08-14-2017, 09:47 PM | #3 | |
Rep 1,154
seems like replacing the Crankcase vent hose fixed the other issues that it had caused. all is well now. |
08-14-2017, 10:04 PM | #4 |
Rep 112
I just think it's unacceptable given your mileage. My 5 series has 75k on it and runs like a top. Never had to replace a single thing.
08-31-2017, 12:53 PM | #5 |
Rep 263
I think my car is undergoing the same thing. Light came up on at around 29k miles. Should be fixed and picked up later today. My SA said it was the hose as well.
2007 Lexus ES350
2007 Lexus RX350 2005 Lexus ES330 1972 Mercedes Benz 280 SEL 2014 BMW 550i |
09-04-2017, 07:55 PM | #6 |
Rep 1,154
fucking car got flat bedded again today to the dealer, was at a light, and the car was idling just fine,when all of a sudden it started idling rough
check engine light flashing white smoke from exhaust (my mom was following behind me in my other car so she told me that) drivetrain malfunction. 26k miles!! hopefully this isn't a sign of things to come and maybe its just a coincidence that this happened so soon after the above issue a few weeks back. we'll keep y'all posted |
09-06-2017, 12:52 PM | #8 |
Rep 1,154
Text from SA
Shailen, we are getting a lot of misifire error codes. The tech suspects it could be the high pressure fuel pump or the injectors we are still in the diagnosis phase. I do know that I need to keep the car till tomorrow. Kin I asked him why this would happen at such a low mileage I wish I knew Shailen, I doubt anyone can predict when parts will fail. I know you have low miles on the car must be manufactured defects showing up. --Kin Salas Stevens Creek BMW |
09-06-2017, 01:58 PM | #9 |
Rep 1,154
latest update as of 3pm PST on Weds
Hey Shailen, we replaced 4 injectors and 4 spark plugs. Car is running normally now. asked him to replace the other 4 in the other bank, as if these 4 failed (still don't know why) then whats to say the other 4 aren't too far behind. they are 2 different banks. Unfortunatly I can not replace the others unless they are failing BMW will not cover them if we cant show failure to them. his response back Totally understood. we have rechecked after replacing the injectors and no error codes coming back. If I could I would like to keep the car until Friday to keep checking it an putting a few extended road test to make sure issue does not come back. |
09-06-2017, 02:02 PM | #10 |
Rep 1,154
Has anyone with a n63tu had their injectors replaced at such low mileage? could this be caused by bad gas? or by using fuel injector cleaner (seafoam) in the gas tank???
09-06-2017, 05:19 PM | #11 |
Rep 382
Drives: 16 F10, 19 xm40i, 24 x7
oh man, I know it sucks. I hope that is the last and car is back and going strong moving forward. Under 25k is what got me concern.
09-06-2017, 10:27 PM | #12 |
Rep 1,154
and to top it off the radiator blew up in my DD 2000 camry, which i've had since new (100 miles), original radiator with 281k miles on it blew up after 17 yrs....
talk about extremes LOL |
09-06-2017, 11:51 PM | #13 |
Rep 5,356
09-07-2017, 12:14 AM | #14 |
Rep 1,154
09-21-2017, 04:57 PM | #15 |
Rep 659
