2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Shake in front w/spacers
      09-07-2014, 09:15 PM   #1
Sick2010535
Drives: 2010 BMW 535i
I have a set of 235/40/19 vmr 710 that are high speed balanced and mounted perfectly. Rims are straight and no issues. I have 12mm spacers on it. Before I did the high speed balance, they shake between 50-75 was worse. After its calmed down but the shake is still there. I purchased the spacers from eBay. I was told that the spacers are ok but they are cheap and thats why the shake. Can anybody please help me out..
      09-07-2014, 10:37 PM   #2
550Reasons
550Reasons's Avatar
Drives: F10 550i
yea that could be the problem, they arent hubcentric probably too
2011 550i
2013 M5
2014 M5 CP
2016 550i
      09-08-2014, 04:05 AM   #3
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
Any shake without the spacers?
      09-08-2014, 07:28 AM   #4
Sick2010535
I haven't tried because I need em in the front. I have 19x9.5 in front and 19x11. What is the diff between hubcentric and lug centric
      09-08-2014, 08:05 AM   #5
Mr Clean
Mr Clean's Avatar
Drives: F10
I don't have an answer to your question, but I will research and try to get back to you on that, but I do have a suggestion to offer. But first, story time!
I had spacers on my e39 and the car would vibrate and shake at the speeds you described. They were the ECS tuning brand with extended lugs and very well made. Keep in mind I was always taking my wheels off due to being a busybody and constantly adjusting my coilovers and doing other mechanical work. One day I was due for an alignment and one of the workers shook my wheels to make sure I didn't have any damaged suspension components (which wouldn't allow me to get the proper effects of the alignment) and he found that I needed a new tie rod. I said to him, there's no way I did it last month and we argued for a while. He decided to do the alignment anyway and took the wheel off by hand since the impact wrench was in use. To his surprise the wheel came off quite easily and as he took a closer look at the other wheels he realized I didn't seat the spacers correctly and as a result, the lugs couldn't properly tighten thus causing my vibration at speeds. What he did to seat the spacers correctly was to clean the hub, clean the center bore of the wheels, put the spacers on, and without the wheels, use the impact wrench to tighten the lugs in a star configuration. Then he would remove the lugs and put the wheels on and tighten the wheels. After that, I never experienced any shaking again. It was a s simple as that. Try that out and see if your problem is solved.
Follow me on Instagram: MrcleanF10
      09-08-2014, 07:19 PM   #6
VMRWheels
VMRWheels's Avatar
2042
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
As others have mentioned above :
- Confirm hub-centric (72.6) and lug centric (5x120). + Use of appropriate length lug bolts
- Clean hub surface area off (free of rust/dirt) - Wire brush usually does the trick
- Torque spacers|wheels down to appropriate spec (star pattern)
If the shaking still persists.. see if it exists without the spacers. There is potential that other variables could be involved.
Tags
bmw 5 series f10, high speed stability, vmr 710
