09-26-2013, 08:31 AM | #1 |
Rep 966
No Boost?
So I'm driving last night and notice that my car feels a little sluggish. I step on the gas and realize there's no boost (found myself leaning forward in anticipation of the push back in my seat that never came) Boost gauge verified that the engine never saw boost (peak recall was 0.00psi)
Car was fully warmed up, no lights on the dash or control messages, full throttle in 2nd and 3rd gear for at least 2-3 seconds each and nothing. I tried with DTC on and off, same result. Restarted the car and it went back to normal, couldn't replicate it this morning either. Anyone else experience anything like this before??? |
09-26-2013, 08:49 AM | #2 |
Rep 8,809
Very strange......I would imagine the car would throw faults right away in a situation like that.
Keep us posted.... Alan
09-26-2013, 10:13 AM | #4 | |
Rep 966
I've never experienced limp mode myself, but it felt like the way people describe what happens when that occurs. However I didn't experience any lights on the dash or messages in iDrive. I'll scan it with my BT cable when I get home tonight and see if there are any 'hidden' codes thrown. |
09-26-2013, 07:55 PM | #5 |
Rep 966
Here are the fault codes. I'm contemplating whether I should clear the codes and see if it happens again, or just bring it in and see if these cause any concern.
Short Test Digital Engine Electronics Current Fault Codes 1F0201: DME, internal fault, checksum: Memory module check Dynamic stability control No Faults Found Tyre Pressure Monitor No Faults Found Car Access System Current Fault Codes 93076A: Deactivation of terminal 15: upper startability limit reached, but deactivation preventer active 93076B: Deactivation of terminal 30B: upper startability limit reached D91410: Message (drive train 2 data, 230.0.2) incorrect, receiver CAS, transmitter DME / DDE Instrument cluster No Faults Found Crash Safety Module No Faults Found Integrated automatic heating / air conditioning system Current Fault Codes 8011FD: Ioniser: Signal line, short circuit to ground or open circuit Footwell module No Faults Found Central Gateway Module Current Fault Codes 801C15: Fault is stored Junction-box electronics No Faults Found Switch center, steering column No Faults Found allround-view camera No Faults Found Active steering No Faults Found Electronic fuel-pump control No Faults Found Integrated Chassis Management No Faults Found Parking brake No Faults Found Rear-axle slip-angle control No Faults Found Electromechanical power steering No Faults Found Combox Multimedia No Faults Found Top HiFi amplifier No Faults Found Vertical Dynamics Management No Faults Found Function Center, Roof No Faults Found Combox emergency call No Faults Found Car Information Computer No Faults Found Park Distance Control No Faults Found Controller No Faults Found Rear-lid lift No Faults Found Seat module, driver No Faults Found Front passenger seat module Current Fault Codes 802B9B: Motor, head height adjustment: short circuit, low side, to negative or open circuit Central Information Display Current Fault Codes 800334: CID: PWM reduction on account of overtemperature Fault is stored in memory but is not currently occuring Rear-cabin automatic A/C No Faults Found Damper satellite, front left No Faults Found Damper satellite, front right No Faults Found Damper satellite, rear left No Faults Found Damper satellite, rear right No Faults Found |
09-26-2013, 08:14 PM | #6 |
Rep 62
Interesting range of faults reported. Maybe a failing battery is boogering things? Let us know if you have it in for work.
Best regards,
Don M |
09-26-2013, 09:53 PM | #7 |
Rep 8,809
I would print that out and bring the car to the dealer. You don't want that crap to happen again. Any mods on the car?
Alan
09-26-2013, 10:43 PM | #8 | |
Rep 217
Drives: shifting priorities for now...
09-27-2013, 10:17 AM | #9 |
Rep 966
09-27-2013, 10:19 AM | #10 |
Rep 966
09-29-2013, 06:36 AM | #11 |
Rep 217
09-30-2013, 09:35 AM | #12 | |
Rep 966
I have a feeling that they are going to do the 'couldn't replicate the issue' thing, but it's probably worth bringing in for them to see the codes it threw anyway. Plus my front brakes are starting to make noise so I have another reason to go... |
09-30-2013, 09:45 AM | #13 | |
Rep 217
