2010 2011 BMW 5 Series Forum F10 F10/11 screen scratch - DIY |
04-19-2014, 03:44 AM | #1 |
Elderly Member
Rep 42
Drives: Porsche Cayenne x45e on order
Reading the many posts on various forums about scratches in the coasting on the nav screen I decided to tackle mine.
I felt the only way to completely remove the scratches would be to completely remove the coating, time will tell whether I need to add an anti-glare protector but to be honest my screen is barely visible when the sunroof is open even with the coating on. Tools required: - Torx T20 (to remove the screen) Torx T9 (to separate the housing from the screen) Novus plastic polishing kit purchased from Amazon for £15 I didn't fancy doing it in the car so I removed the screen as per the youtube video Having removed the screen i separated it from the housing by removing the 3 torx screws that hold the back box on and then 4 torx screws that hold the screen to the housing The good thing about doing this is that as the housing bezel sits over the outer edges of the screen you don't have issues with not getting all of the coating off tight into the corners. You can see how badly scratched my screen was from the photo. Once separated I removed the coating using the novus 3 polish and then went over the screen with the novus 2, I was careful not to put too much pressure on the screen and the whole process took about 40 minutes as you can see once this was done the screen was flawless. The screen is now back in the car and although it's not particularly sunny today the reflections look no worse than they did before. Hope this helps anyone else who fancies a go at doing it themselves
There are 10 types of people - those that understand binary and those that don't
04-19-2014, 01:21 PM | #3 |
Elderly Member
Rep 42
can't say, got the car at 18 months old ex lease and I'm guessing the previous owner didn't love his car. I was appalled when I realised the screen was so scratched but you could only really see the scratches when the screen was off
04-19-2014, 05:30 PM | #4 |
Rep 7,000
Fair enough, my ex lease cars are normally immaculate when they go back, saying that some of my colleagues cars are a total disgrace.
Good write up though, hope I never need to use it! |
04-20-2014, 03:10 AM | #5 |
Rep 67
number of people I give lifts to who assume in this day and age that the car has a touch screen. maybe the previous lease owner thought the same and was a little slow on the uptake...
04-21-2014, 06:24 PM | #6 |
Rep 203
As soon as I bought the car I bought a screen protector. Great idea and solved all of these problems before they even appeared...
04-23-2014, 02:31 PM | #7 | |
Rep 197
Drives: MY10 F11 520d SE
