2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Standard speakers upgraded to OEM Top Hifi (retrofit)
      10-03-2013, 10:45 AM   #45
GhostWorks
Drives: F07 530D SE GT ( 2010/07 )
Looks good, I got my F07 ( 530D SE GT ) with standard sound ( 4 x mids and 2 x subs ) be nice to upgrade to top Hifi tweeters in front door pillars and the mids in the doors and see how that rocks as the bass is good from under the seat just needs more clarity ,definition and height
has anyone done just that ? on F07 or F10 / F11
O1NE0.00
      10-12-2013, 10:43 AM   #46
vince59
Drives: x3 f25
is there a schematic were to understand ohm values for different setup?
I have a european x3/f25 model with professional navigation so no clue what is the hifi setup.
I know I have no tweeters but I bought cheap used top-hifi tweeter willing to add these to the existing mid/sub unit.
Will I affect (lower) the impedance?
Thanks
      10-12-2013, 10:46 AM   #47
vince59
Drives: x3 f25
can someone please reply to give me infos..and full capability to post new thread to the forum? Thank you so much!
      10-14-2013, 01:04 PM   #48
vince59
Drives: x3 f25
no help..no reply WTF??
      10-15-2013, 01:03 PM   #49
vince59
Drives: x3 f25
wtf
      10-16-2013, 07:46 PM   #50
fung0001
Drives: f10 2013 520i Hartge Tuning
Originally Posted by Technic View Post
OP's system is the Stereo, where the iDrive powers the 6 speakers (front, rear and underseat) directly with just 25W per 4 channels; no tweeters and no external OEM amp.
The Stereo underseat woofers are connected in parallel to the door mids, thus the 4 wires at the woofers. All mid and underseat speakers are 4 ohms in the Stereo system, but because the front and the underseat woofers are connected in parallel the iDrive front load is 2ohms. The iDrive is stable at 2 ohms.
Why all this explanation?
When you replace the OEM speakers in the Stereo system you are actually changing as well the load to the iDrive unit. Because the front and woofers are connected in parallel then things could get messy if the load drops below 2 ohms -as in replacing the mid and underseat woofers with Top HiFi (677) speakers for example. Top HiFi mid + tweeters speakers become 2ohms when connected together and the woofers are 4 ohms by themselves. When connected in parallel (not designed to be connected in parallel in the 677 or 676 systems) they will create a load to the iDrive of 1.33ohm.
The iDrive unit is not stable at 1.33ohm.
So before any speakers are replaced in the Stereo system you should take a look to what you are actually doing to the iDrive unit. The system will sound great at the beginning just because the lower the load the higher the power output. But that higher output comes with more heat inside the iDrive unit. More heat that was not intended by design to be there.
Your iDrive unit will overheat sooner or later, and then it will just fail.
Take care...
Is it mean not recommended to add speaker from 6 to 10 in standard sys? Thks
      10-22-2013, 03:24 PM   #51
vince59
Drives: x3 f25
if replacing audio base loudspeakers (single midange without tweeter) with hifi speakers (midrange PLUS tweeter) is there any problem for the audio amp to drive two speakers (less resistance value) instead of a single one?
      10-23-2013, 07:34 PM   #52
Micah D. Cranman
Drives: 2016 M3 Messing over Nutmeg
No -- tweeters in this context don't significantly change the load presented to the amplifier.
      10-23-2013, 07:35 PM   #53
Micah D. Cranman
By the way, great job and thanks for sharing. For the record, you *could* have contacted us for plug and play upgrades which sound EVEN better than the Harman Kardon speakers.
      10-26-2013, 05:25 AM   #54
Technic
Technic's Avatar
2288
Drives: 2021 i3S, 2024 i4 M50
Micah... this is the Stereo system, not the HiFi. The 6.5" woofers are connected in parallel to that single mid. Adding a tweeter to the mid will make 3 speakers connected in parallel, thus increasing the load/decreasing the impedance unless something is done with the woofer.
The iDrive unit can handle 2ohms according to BMW. Less than that and the unit will overheat.
This has to be done the right way.
      10-26-2013, 05:33 AM   #55
Technic
Technic's Avatar
2288
Again, if your standard system is the Stereo then you should disconnect the woofers from the mid and then add the tweeters.
This has to be done anyways for two reasons, impedance and to make the woofers sound the best with what you got. They should have their own amplifier channel so each can be tuned/crossovered more efficiently. There is no filter or crossover between the woofer and the mid with the iDrive system, so the sound is just split (highs/mids/lows) by each speaker own frequency response and that's it.
O1NE0.00
      10-26-2013, 07:14 PM   #56
fung0001
Got it thks
So is it a choice between tweeter/ woofer unless amp is added for the latter?
      10-27-2013, 08:05 AM   #57
Technic
Technic's Avatar
2288
Got it thks
Correct, if you want to do it the right way.
      10-28-2013, 08:54 AM   #58
fung0001
Thanks
Btw, i have come across this
http://www.focal.com/en/dedicated-driverspeaker-kits/396-ifbmw-c-3544051750530.html
Is it compatable with f10 ?if yes, just replace front door speaker with this and sys safely improved? Thks
      10-28-2013, 09:44 AM   #59
Technic
Technic's Avatar
2288
Thanks
http://www.focal.com/en/dedicated-dr...051750530.html
I do not know if the new Focal set fits the F10 -if it fits the E92 then most probably it fits the F10. Regardless, you still have to separate the woofers from the mids anyways.
      10-28-2013, 10:12 AM   #60
fung0001
oh no
thanks tech
Manual says that it is compatible with 1 Series, 3 Series and X1
can't imagine why 5 series is not on the list
http://www.focal.com/en/dedicated-dr...050750531.html
may be first stage, cut woofer & install some compatible stuff like ifbmw-s ( rock & roll is not my cup of tea)
then second stage amp for woofer ( any cheap & simple installed amp in the market recommended?)
      10-29-2013, 09:28 AM   #61
fung0001
Ooops!
i just found this from BMW HK: Radio BMW Professional, four-channel amplifier ( have amp in standard stock?), double-tuner reception,
aerial diversity, scan function, CD drive with MP decoder, six loudspeakers.
      10-29-2013, 04:31 PM   #62
Technic
Technic's Avatar
2288
Ooops!
That's your iDrive unit. There is no external OEM amp in your car.
      10-29-2013, 04:41 PM   #63
fung0001
What is the meaning of 4-channel amp?i suppose this mean amp for 2 front speakers and 2 rear speakers.
Sorry for such stupid question
      10-30-2013, 11:27 AM   #64
Technic
Technic's Avatar
2288
The iDrive unit has a built-in 25W x 4 (max) amplifier.
      10-30-2013, 05:58 PM   #65
fung0001
Yes you have mentioned earlier
The idrive is stable at 2 ohm
Am i do it the right way as follows:
Front: 2 Tweeter + 2 mid speaker in parallel
Rear: 2 woofer + 2 mid speaker in parallel
      10-31-2013, 04:26 AM   #66
Technic
Technic's Avatar
2288
You need to run new cables to the underseat woofers (thus separating the front from the woofers), that's the easiest and the right way.
