2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 295 or 285/30/20 on a 10.5 inch rim.
      03-01-2015, 08:51 PM   #1
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
Hello, anyone have pics of both? I'm trying to look at the taper of the sidewall or will it be square?
      03-09-2015, 07:57 AM   #2
Azimmerlyjr
Drives: 2012 550i RWD Black on black
Rear is 20x10.5 et32 285/30/20
Front is 20x9 et28 255/35/20
Th rear has a little stretch to it and the front is pretty much even with the wheel.
      03-09-2015, 08:04 AM   #3
Azimmerlyjr
Better pics...front then rear...
      03-09-2015, 08:08 AM   #4
Azimmerlyjr
Im guessing the 295's would be pretty much dead even with the wheel very similar to my front wheels/tires
      03-09-2015, 08:18 AM   #5
Azimmerlyjr
Rear
      03-09-2015, 10:36 AM   #6
valbmw
valbmw's Avatar
94
Drives: 2016 BMW F10 M5 CP 600 hp
Example of 245 on 8.5" and 285 on 10.0"
Guys, my experience says, the square (and maybe the perfect) fit is: 8.5" to 245, 9.0" to 255, 10.0" to 285, 10.5" to 295. Otherwise you will have either stretch or donut. I would avoid both deviations on my car, because of different reasons.
Have a look at my summer tires sitting on balcony. They are 8.5X20 245 and 10.0X20 285, Michelin PSS. Tires have a kind of a sharp sidewall flange (red outline) at the 245 fronts, probably to protect the rim. So the rubber pokes 4 mm out at fronts (flange) and 1 mm at the rears, and sits flush like hell, see the picture:
Size:  175.4 KB Name:  IMG_0180.JPG
Size:  59.1 KB Name:  IMG_01751.jpg
      03-09-2015, 10:39 AM   #7
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
Thanks a lot. changes also with tire brand. Think i'm going michelins .
      03-09-2015, 05:39 PM   #8
Vinfast
Drives: '14 550i M-Sport
My 295's on my 295 michelin pass hit the fender on big dips. I had to switch
back to 285s.
      03-09-2015, 06:46 PM   #9
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
back to 285s.
what offset? on a 10.5 inch rim?
      03-10-2015, 05:48 PM   #10
Vinfast
I think they were 35.
      07-26-2020, 05:54 PM   #11
tonytony99
tonytony99's Avatar
Drives: 2014 528i
same setup with coilovers?
hey friends, Going to do a 20x9 and 20x10.5 with 255/35/20 and 285/30/20.
My only concern is rubbing after dropping the car on coilovers..?
What are your guys thoughts? Will it work? I have been researching for quite some time and haven't been able to come to a conclusion..
Maybe going to a less wide wheel will work better?? any feedback is much appreciated.
2016 528i non m sport.
      07-26-2020, 10:54 PM   #12
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
you need to provide the offsets
      07-27-2020, 01:35 PM   #13
tonytony99
tonytony99's Avatar
Drives: 2014 528i
OFFSETS
they are +35 for the front and the rear!
      07-30-2020, 12:32 AM   #14
d00bies
Drives: m4
https://www.willtheyfit.com/
