2010 2011 BMW 5 Series Forum F10 2 types of lubricants in CV Joint boot kit |
12-24-2021, 04:13 PM | #1 |
Rep 26
Hi,
I bought the OEM CV Joint boot kit like this: https://www.google.pl/search?q=31607...UTF-8&hl=en-gb The problem is that I got 3 lubricants: - 2x One-Luber GKN (100g) - 1x GKY H-15 (100g) Does anyone know where I should add these? I know that at least one (probably One-Luber 200g should go into the CV Joint boot but what’s the purpose of GKY H-15 then? |
12-26-2021, 09:34 PM | #2 |
Rep 1,039
I think I may have screwed this up and put the incorrect lube in the outer joint. I replaced a torn outer boot and didn't realize there were two different lubes in the kit until it was too late. IIRC, there was a dark green lube in the outer from the factory, and the lube I put in was more silver? That's going by memory though, so may not be accurate.
12-27-2021, 12:30 AM | #3 | |
Rep 2,591
2015 BMW 535xi
12-29-2021, 10:26 AM | #4 |
Rep 1,039
I hope you're right! Oh well, it's holding up so far and if the joint does go bad I'll just end up replacing the shaft like I almost did initially anyway. The boot kits are not expensive, just labor intensive to install and I have more time than money.
