2010 2011 BMW 5 Series Forum F10 How many F10 N55 owners had a charge pipe cracks? |
05-04-2018, 02:30 PM | #45 | |
Keepin' America Free
72
Rep 1,260
Anyway after an hour of pushing and pulling from all 3 sides of the engine bay, it finally went on. I had to wiggle it for about 5 minutes straight under pressure from different angles until it finally went on all the way. I was literally laying across the engine bay with my feet in the air trying to slip it into place, dripping sweat, and cursing up a storm.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough" -Mario Andretti |
T-Bone1822.00 |
05-04-2018, 02:32 PM | #46 | ||
Rep 1,890
05-04-2018, 04:19 PM | #47 | |||
Rep 4,632
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
05-04-2018, 04:38 PM | #48 | ||||
Rep 1,890
05-05-2018, 11:20 PM | #50 | |
Rep 4,632
I think the oem CP can survived alot long if some super glue or adhesives is laid around the sensor holder ( Since this seems to be a area we are seeing some common failures at). Here is the ER chargepipe install on the F10... Slid onto the throttle body with ease.
05-05-2018, 11:21 PM | #51 |
Rep 4,632
https://www.ftpmotorsport.com.tw/pro...55-charge-pipe
Seems to be a full one piece CP? The value seems great with this one since it includes the oem clip and seal. But as always, its all about fit and seal at the throttle body, any experiences? I got my eye on the ER chargepipe, good price and very solidd company with bmw turbo performance parts for years.
05-07-2018, 07:06 AM | #53 | |
Rep 1,693
These cars would be rubbish and weigh well over 2 tonne and way more expensive too if BMW made every part that's plastic out of Aluminium. The issue is they didn't quite put enough thickness and/or adhesion in a couple of spots for increased boost levels. I've ran my N54 with upgraded turbos on 17psi for years with the stock charge pipe. Plastic is an excellent material. It's the implementation of that plastic that varies. |
05-07-2018, 02:41 PM | #54 | |
72
Rep 1,260
Lesson learned
5soko333.00 |
05-21-2018, 06:13 PM | #55 |
Rep 4,632
After digging into the F10 chargepipe issues, i have found that the F10 N55 has had 3 versions of chargepipes in its liftime.. The latest and greatest chargepipe do not come with a support hold or mount in the middle of them. Those started in the MY2014 F10 N55's.
Black plastic welder... sets in 10 minutes, 5 minute working time.. Cures in 24 hours. Wire ties to hold it down while the it sets. Preventive maintenance. This thing is never coming off lol.
10-08-2018, 10:24 PM | #57 |
Rep 1,893
LMFAO the sensor port blew off of my charge pipe over the weekend. My wife called her uncle who is a mechanic and told him I need help because I was gluing (JB Weld) parts of my car back together. Glad to come here and see my idea wasn't too far off, I added the zip tie too lol
10-09-2018, 07:13 PM | #58 | |
72
Rep 1,260
People also like to think luxury cars are diamonds. They're just cars, they work the same way. Air goes in, add some fuel, a spark, and compression and you have power. In this case it's simply pressurized air, zip tie a glue will get you through! But I would definitely recommend replacing it with a better one. You'll be running at 95% efficiency until then.
10-09-2018, 11:54 PM | #59 |
Rep 441
Was also losing my mind trying to get my vrsf CP on to the throttle body...I think it was just the dry o ring and dry metal against metal making it too tough
Rubbed vasoline around the inside of the vrsf CP making sure to cover the o ring and then it magically slid on to the throttle body. Was almost worth the earlier agony for the sweet sweet relief when it finally easily slid right on |
11-05-2018, 06:47 AM | #60 |
Rep 51
Drives: e63 650i, F10 535i, E93 335i
Mine blew the TMAP sensor off too, peak boost @ 20psi.
2012 535i M-Sport PWG, Wagner FMIC, VSRF no meow, chargepipe, Walbro 450 with custom fuel lines, MHD map e30 2+, JB4 (monitor and logging only now), xHP Stage 3, K&N drop-in, Paddleshift retrofit
11-06-2018, 07:56 PM | #62 |
Rep 4,632
Been running my OEM chargepipe for a while now at 14 psi with catless downpies, so far so good.. OEM chargepipe has held up well.
11-07-2018, 06:30 PM | #63 |
72
Rep 1,260
Nice man. Mine blew about 4 weeks after switching to a catless DP.
11-08-2018, 06:45 AM | #64 |
Rep 431
I am stage two (recently switched to MHD stage 2 after installing ER catless dp) and have not really pushed the car for the fear of destroying my chargepipe. VRSP went on sale yesterday, and I immediately placed an order for one. Only if VRSF would hurry up with their intercooler I would do a stage 2+ and start logging.
01-03-2019, 01:38 PM | #65 | |
Rep 4
Drives: 2011 F10 535i msport
No issues with stock charge pipe but my mechanic strongly recommended upgrading for long-term reliability. |
01-04-2019, 02:37 PM | #66 | ||
Rep 639
