2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications MHD Tuning Post Your Logs
      08-01-2018, 07:58 PM   #89
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
Originally Posted by harris69 View Post
Mine? ~108 °F I think. When I am in boost I have seen it get up in the ~134-136 °F.
Mine during the day when it's like 95 degree outside... iat hits 135-145
      08-02-2018, 08:09 AM   #90
harris69
Drives: 1997 M3/4, 1984 533i,1997 328i
I normally datalog around 5:40 am (on my way to work) and most days ambient is in the high 60s. So, to go from 68-74 to 129 degrees in one run is pretty significant. But, temps drop quickly after I datalog.
      08-09-2018, 01:56 AM   #91
ey2001
ey2001's Avatar
310
have heard you guys are getting ready to release your intercooler for F10 application, and was wondering if it was going to be anytime soon. I am ready to pull the plug on one and just thought I'd ask you before buying the Wagner unit.
Thanks.
Tayyab.
They arrive and ship in about 3-4 weeks! You'll definitely want to hold off, our solution is just as large with a denser fin pack and it's about $2-300 less expensive
Thanks. I think I am going to wait out for your unit then. Thanks for replying...
Any updates on the intercooler?
      08-09-2018, 06:29 AM   #92
harris69
None...I am so close to saying F... it and going with the Wagner. I am getting my plugs changed tomorrow (going with NGKs ) and chargepipe, and intercooler are next.
      08-09-2018, 06:32 AM   #93
harris69
Here is another log from a few days ago. What do you guys think?
https://datazap.me/u/harris69/aug089...30-31-32-33-34
      08-09-2018, 10:41 AM   #94
ey2001
ey2001's Avatar
310
It is pulling timing more than -3 on cyl 6... see how it is after the plugs
      08-09-2018, 11:03 AM   #95
harris69
Haven't changed them yet. I get them changed tomorrow.
      08-10-2018, 05:47 AM   #96
harris69
Here is one from about an hour ago.
https://datazap.me/u/harris69/aug099...30-31-32-33-34
      08-13-2018, 07:58 AM   #97
harris69
Latest log after swapping out the plugs- went with NGK 97506 using whatever gap they come with from NGK
https://datazap.me/u/harris69/aug139...30-31-32-33-34
      08-13-2018, 04:23 PM   #98
ey2001
ey2001's Avatar
310
maybe you should try running 91 map
      08-13-2018, 07:46 PM   #99
harris69
It is a 91 map with 93 in the tank.
      08-13-2018, 07:49 PM   #100
ey2001
ey2001's Avatar
310
Don't know what to say... I'm on 91 map but I mix 2 gal of e85 and I get no timing pulls
      08-13-2018, 10:16 PM   #101
harris69
I didn't gap down, (which I think I should have) and I have been running 93 octane since day 1. I wish we had E85 here cuz that would really solve my timing issues.
      08-13-2018, 10:19 PM   #102
ey2001
ey2001's Avatar
310
Do you have access to 100 octane?
      08-14-2018, 07:01 AM   #103
harris69
Not that I can find locally..A friend of mine gave me a half-quart of Boostane a little while ago to try it out. I finally threw it in the tank and filled up with 93 octane, and tuned back to 93 octane. Check out my log from this morning.
https://datazap.me/u/harris69/aug14?...30-31-32-33-34
      08-14-2018, 10:05 AM   #104
ey2001
ey2001's Avatar
310
Looks good....
      08-14-2018, 03:53 PM   #105
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
When you guys are running e85, is that harmful to the fuel system? At what percentage is it safe to run?
      08-14-2018, 05:53 PM   #106
ey2001
ey2001's Avatar
310
A lot of ppl run it... my friends used it on their n54... there are a lot of mix reviews about it... I heard PWG Cars could take more than ewg. I think some ppl on the forum run 4-5 gals... technically if you want to run e30 maps you need 5 gals depending on what the content ethanol is
      08-23-2018, 05:39 AM   #107
harris69
Log from this morning:
https://datazap.me/u/harris69/aug23?...30-31-32-33-34
      08-23-2018, 11:29 AM   #108
ey2001
ey2001's Avatar
310
cyl 4 is pulling a lot of timing... this is mine.. 1st, 2nd, 3rd...
https://datazap.me/u/ey2001/1st-gear
      08-23-2018, 11:37 AM   #109
harris69
No pulling, but you didn't datalog in 4th gear either. Try doing a pull in 4th.
It's at higher rmps that my car pulls timing; best way to find out if yours does that is to leave it in 4th.
      08-23-2018, 11:40 AM   #110
ey2001
ey2001's Avatar
310
No pulling but you didn't datalog in 4th gear. Try doing a pull in 4th and then post it here.
It's at higher rmps that my car pulls timing, and best way to know if yours does that or not is to leave it in 4th and redline it.
I am 6 spd so I do it on 3rd... once I do a 3rd gear pull I will post it for you..
