05-28-2016, 01:41 PM | #1 |
Rep 6
Help With 135 Wheels!!!
I NEED HELP BADLY!
I FOUND A SET OF 135 STYLE WHEELS ONLINE WITH TIRES FOR DIRT CHEAP SO I PICKED THEM UP BUT NOW I REALIZED THEY DONT FIT ON MY 528XI PROPERLY. THEY LOOK WAY TOO TUCKED IN. THEY ARE 19X8J ET35 AND 19X9J ET 45. I NEED TO KNOW WHAT KIND OF WHEEL SPACERS I NEED TO GET AND IF GETTING A SET OF OEM 19" TIRES FROM A 550XI M SPORT WOULD WORK??!! HERE IS APIC OF THE BACK OF THE WHEELS I THINK IM READING THE SIZES RIGHT??? THANK YOU FELLAS! https://drive.google.com/open?id=0B5...RiQmRETi1mbUJv https://drive.google.com/open?id=0B5...FHOXJMbUVMMG1N https://drive.google.com/open?id=0B5...FkNzlNb0hXZnRv |
05-28-2016, 08:21 PM | #3 |
Rep 244
BMW Style Wheels (http://www.bmwstylewheels.com/) is a good reference.
Looking at the Style 135 (which I have on my e46 330i ZHP), they came in a number of different offsets, none of which are what you say you have. So double check the offset stated on the backside of the wheel, and make sure they are really Style 135. Check out the offset of the wheels your 528xi has, then do the math. That will tell you what spacer you need to make things even out. EDIT: Google won't let me look at your pics. Says I need to request permission.
Mike
'04 330i ZHP '11 535i |
05-28-2016, 10:16 PM | #4 | |
Rep 14,521
05-28-2016, 10:31 PM | #5 |
Rep 6
Pics
05-29-2016, 07:39 AM | #6 |
Rep 29,202
They got to be reps since they're 19". 15mm to 20mm spacers in the rear will help.
05-29-2016, 12:40 PM | #8 |
Rep 5,140
The rear wheels are 3mm more aggressive compared to the fronts if your offsets are correct.
I.e. you can fit the same spacer size on all four corners, 15, 18 or even 20mm depending on how aggressive you like to go. |
