2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Fix F10 code errors (help)
      09-10-2018, 08:23 PM   #1
hpgunitd12
hpgunitd12's Avatar
Cayman Islands
19
Drives: F10 535i N55
Need help to solve these errors codes
I tried cleaning all but they came back
I use BimmerLink app to do the diagnostic
Here is what I got
(F10 535i)
**Info memory**
38 errors total
JBBF
3 errors
002031: VSM_EVENT_VEHICLESTATE
002040: PDC: RESET DUE TO WATCHDOG TIMEOUT
002044: K-LIN_5: LIN MANAGEMENT DESYNCHRONIZATION
SZL
1 error
803450: NVRAM MANAGER: WRITE FAILED
ZGW
3 errors
100601: UNEXPECTED ASYNCHRONOUS STATE ON FLEXRAYBUS
100100: CONTACT TO FZM SLAVE LOST
100204: MESSAGE MONITORING: SYSTEM CONTEXT SIGNAL FAILED
ASA
4 errors
16004C: DEM_EVENT_KFC_KL30_UNDERVOLTAGE
16004E: DEM_EVENT_KFC_KL15_UNDERVOLTAGE
160070: DEM_EVENT_ZFLS_UNDERVOLTAGE
160086: DEM_EVENT_KFC_INFO_FRPHYS_REINIT
ICMQL
1 error
482627: CENTRAL ERROR MEMORY BLOCK ACTIVE
DSC
1 error
480A18: DRIVING POWER REDUCTION - DRIVING POWER REDUCTION SWITCHED OFF BY DSC COMMAND - INFO ENTRY -
HSR
9 errors
2B004C: DEM_EVENT_KFC_KL30_UNDERVOLTAGE 2B004E: DEM_EVENT_KFC_KL15_UNDERVOLTAGE
2B0076: DEM_EVENT_KFC_AGB_LIMIT
2B0118: DEM_EVENT_KFC_SKE_IS_FKT_ERR
2B0094: DEM_EVENT_KFC_INFO_ZWK_UNDERVOLTAGE
2B0095: DEM_EVENT_KFC_INFO_ZWK_PL_UNDERVOLTAGE
2B009E: DEM_EVENT_KFC_INFO_FRPHYS_REINIT
2B0105: DEM_EVENT_KFC_SLGS_STARTUP_PWM
2B010B: DEM_EVENT_KFC_SLGS_STARTUP_PWMK
EPS
1 error
482344: LLP ERROR (KFC_LLP)
TVM
7 errors
DBC440: MONITORING CIRCUIT HAS TRIGGERED RESET
930040: SENDER NODE: ERROR IN SEGMENTATION
DBC445: EHC HAS TRIGGERED A RESET IN CASE OF A FATAL ERROR FROM THE INIC
930035: TRANSMISSION ERROR IN THE HARDWARE ABSTRACTION LAYER
4B0008: TOSHIBA HW ERROR - MPEG APPL I2C
4B0048: DTC TO FAILURE MESSAGE
4B0018: TOSHIBA SW ERROR - MPEG APPL, BCAS HARDWARE
KOMBI
2 errors
B7F69E: COMBI: COMMUNICATION SETUP TO THE MOST NODE IN THE STATION WAGON
93003F: MOST OPERATION SENDER NODE: ERROR IN ADDRESSED FUNCTION
MMI
1 error
93000F: MOST NODE: AT LEAST ONE FUNCTION BLOCK LOGGED OFF
PDC
1 error
64430C: MESSAGE (328H, RELATIVE TIME): FAILURE
ZBE
1 error
67000A: CSM_E_ERROR_EVENT
FAS
2 errors
6D0010: NVM_E_READ_FAILED
6D0004: PIA_E_IO_ERROR
CID
1 error
800313: SOFTWARE ERROR: UNEXPECTED RESET
**Error memory**
5 errors
ZGW
1 error
801C20: CENTRAL FAULT MEMORY FULL
CAS
1 error
D91410: DME CAN MESSAGE DATA DRIVELINE: MISSING OR CRC ERROR
FZD
1 error
801A4A: DEACTIVATION OF IRS AND INCLINOMETER BY CUSTOMER FUNCTION
FRM
2 errors
800F3A: FOG LIGHTS LEFT DEFECTIVE
800F3B: FOG LIGHT RIGHT DEFECTIVE
      09-11-2018, 04:59 AM   #2
andykap
Drives: '15 BMW 535 MSport
What year is your car? Is your car in out of warranty? Those error are in memory and could be from several days, months etc. are you having issues with any of those faults? If no, then go ahead and clear the, from memory.
I had memory fault whenever I work on my car, I see them and then clear.
      09-11-2018, 06:03 AM   #3
hpgunitd12
hpgunitd12's Avatar
Cayman Islands
19
It's a 2011 no warranty
I cleaned them the other day but it came back
No check engine light
      09-11-2018, 07:00 AM   #4
andykap
Are you having any issue with any of those errors? Take the fog lights, are they working? If they are then it is rather odd. If you have access to ISTA-D try clearing with that and see.
      09-11-2018, 05:34 PM   #5
hpgunitd12
hpgunitd12's Avatar
Cayman Islands
19
The fog light are fine
I replaced the halogen with leds lights
But the rest I don't know what to do
I use BimmerLink app on my phone to clear the error codes
Is that enough should I go experts method
Witch is using the Ethernet cable to obd2 to laptop??
      09-11-2018, 06:13 PM   #6
jimk
jimk's Avatar
104
Drives: 2018 M550i
How old is your battery? The battery is the first thing I would check.
      09-11-2018, 07:42 PM   #7
hpgunitd12
hpgunitd12's Avatar
Cayman Islands
19
I just bought the car
I Doubt the was previous change
How can i tell if the battery needs to charge ?
The car starts fine
      09-12-2018, 05:57 AM   #8
andykap
When you change to LED did you change the setting, with BimmerCode? If you did not the error will always be there no matter how many time you clear it.
Try this in BimmerCode
FRM
AUSG_25_RFS_R_IS_LED to aktiv
AUSG_24_RFS_L_IS_LED to aktiv
      09-12-2018, 07:25 PM   #9
hpgunitd12
hpgunitd12's Avatar
Cayman Islands
19
FRM
I'm to worried about fog light
I got that fix the led light came with some capacitors
So no more fog light error
I most concerned about the rest of the memory error codes
By the the way
My battery is reading 12.2v
I'm a new owner of the car
Is this what's causing all the troubles ????
      09-13-2018, 05:06 AM   #10
andykap
Go here - https://f30.bimmerpost.com/forums/sh...312102&page=80
you will have to sign up, then request the torrent for ISTA+, run ISTA - D to get more information on the errors you have, then delete them. Then check to see if they come back.
      01-29-2019, 03:22 AM   #11
Andrei525
Drives: BMW 525d
Hi Guys,
I have same problem with few errors in the Info Memory.
Can anyone help me get ride of them?
Info memory
12 errors
JBBF
3 errors
002040: PDC: RESET DUE TO WATCHDOG TIMEOUT 002044: K-LIN_5: LIN MANAGEMENT DESYNCHRONIZATION
ZGW
2 errors
MOTOR
1 error
27AB00: DDE CONTROL UNIT INTERNAL (CYCLIC AUTHENTICATION): DATA RECORD CHECK OUT OF ORDER
ICMQL
1 error
DSC
1 error
KOMBI
3 errors
B7F69E: COMBI: COMMUNICATION SETUP TO THE MOST NODE IN THE STATION WAGON 93000A: FBLOCK WITH METHOD: SIGN OF LIFE DOES NOT COME ON TIME
MMI
1 error
      06-24-2020, 10:26 PM   #12
hossein_au
Australia
Drives: 2011 BMW 740i (F01)
Any update?
Hi guys,
Did you ever managed to find out more about the errors you were getting? Any fixes?
      06-25-2020, 04:46 AM   #13
HotSpicyChicken90
Drives: BMW 535i
http://bmwfault.codes/
With ISTA you could do a full ECU-Reset. As a BMW-Owner you might want to invest in a bmw-diagnose-laptop. It will pay itself after the first use!
please take it in consideration. You WILL save ALOT of money
