2010 2011 BMW 5 Series Forum F10 Anyone Switch from Goodyear Eagle LS2 Runflats to Michelin Pilot Sport A/S 3 ? |
06-18-2015, 10:39 PM | #1 |
Rep 66
Has anyone in the forum specifically, went from the Goodyear Eagle LS2 Runflats to the Michelin Pilot Sport A/S 3 and have some feedback on performance?
For starters, I just bought a CPO 2012 535i xDrive with Sport Package (non M-Sport). Tire size is 245/40/19 and running the stock Goodyear Eagle LS2 RFTs. So far, I pretty much hate the "feet of clay" feeling they're giving the car plus a couple of them are lightly feathered due to a previous balance/alignment issue, prior to me buying it. I know this topic has been discussed before but there seems to be a mixture of folks running different stock OEM tires and I wanted to see specifically who's had the LS2s and then switched to the AS3's. Just wanted to make an educated decision on whether it will be worth it to change to non-RFT. I'm in the DC area and have had experience with sidewall bubbles in my previous Bridgestone Potenza runflats and would think changing over to non-RFT before winter hits, could be a wise choice. A set is running for around $950 total from Tire Rack and a little cheaper at Costco, so would hope this upgrade is worth it before I pull the trigger. Thanks in advance for any input/feedback! |
06-18-2015, 11:34 PM | #2 |
Rep 14,522
I don't have the LS2's but I do have the Dunlop RF's. I'm in the same boat as you. I do have bubbles on my sidewall but I'll be getting some 21's next month. My current wheels I'll swap those RF's for snow tires and use them as my winter set. I've read all the threads regarding pros and cons and the polls but it Seems like a 50/50 here in this 5 series community about this.
06-19-2015, 09:07 AM | #3 |
Rep 82
I switched to the AS3 about 25k miles ago, on 19" M351 OEM M Sport wheels. I'm in the Chicago area, so plenty of potholes/rough roads - no problems to report (no sidewall bubbles, etc). Remaining tread measures 7/32.
06-19-2015, 09:10 AM | #4 | |
Rep 66
06-19-2015, 09:12 AM | #5 | |
Rep 66
06-19-2015, 03:32 PM | #6 |
Rep 82
I did have LS2 before changing. Unfortunately, I only had them for a couple of months before swapping them for the AS3, so I really can't comment on how much quieter/more comfortable they are (new tires always seem quieter). The handling seems sharper, and the driving in the snow has not been a problem with the AS3.
06-21-2015, 06:09 AM | #7 | |
Rep 66
Might I ask, where did you buy your AS3's from? And how many inches of snow did you drive in with them? I'm in the DC area and the past few winters have been pretty bad. I've been pricing around and it seems like Costco and Tire Rack are the cheapest options (around $950) - which is still a little pricey for my tastes lol |
06-21-2015, 08:44 AM | #8 |
Rep 82
No problem. Since the car was new to me, I did not push the handling much with the LS2. I had a bead fail on the LS2, so I didn't keep them long.
As for the feel of the AS3, I think the 550 feels plenty nimble and handles well (especially for a 4400lb + car). I've been very happy with the AS3. I got mine from TireRack, had them mounted/balanced by the dealer (car was already there to see how much an LS2 costs) I drove them in snow up to 6" with what you'd expect for results. It's not a jeep, after all, but xi still keeps things moving. |
06-21-2015, 01:48 PM | #9 | |
Rep 66
Any comments on the ride and noise comfort? The LS2's are pretty bad IMO, but I don't have much to compare to. My other option is the Continental DWS for better snow traction and comfort from what others on the forum have commented on, but I heard their sidewalls are soft. |
06-21-2015, 09:07 PM | #10 |
Rep 472
So I had the Dunlop RFT for 28k on my Msport 550i (same wheels as you), they were my first run flats on any vehicle, and they felt rougher than the big wheels I ran back in the day (22's with a 30 series sidewall) on my E53 X5.
I needed new tires and knew I wasn't going run flats again. The AS3's came out just around the time my tire search started. I wanted the Michelin Pilot SuperSports, but the tread life turned me off as I drive my car Spring-Fall, and store it for the winter. The AS3's seemed to be the best bet, and I do not regret my decision. Great grip, long tread life (almost double of the SuperSports), great turn-in and response. Have had them for about 7k miles and at this stage would definitely buy them again. People say they're loud, but the F10 is so sound deadened you realy can't hear anything. The bumps feel like pudding compared to running over a brick with the run flats. These tires are more agile, and I have had no issues with them at all. Fun Fact: The AS3's are a more "square" tire compared to the rounder sidewall's of the Dunlop's. This makes the tires look beefier and makes me look a tad bit more lowered. Lastly, they suck in the snow, and strongly advise RWD owners with rough winters to choose something else. These were perfect for me because they still have great grip in cold temps (below freezing) and are even better in hotter temps (110F). |
06-22-2015, 08:05 AM | #11 |
Rep 1,126
I just had Michelin A/S 3 installed on msport. Ride is smoother and quieter than rfts. I had sway bar upgrades to m5 in front & 650 sway bar in rear. Without runflats car is little more wobbly. Runflats + bmw sway bars upgrade would feel same as non runflats + H&R sway bars upgrade.
06-23-2015, 12:09 AM | #12 | |
Rep 66
06-23-2015, 12:11 AM | #13 | |
Rep 66
When you say the car feels "wobbly" with non-RFTs and the swaybars...can you provide a little more details on that feel? I would think that it would have the opposite effect, since the AS3's have better grip and balance than the stock Goodyear LS2's. Thanks again. |
06-23-2015, 10:28 AM | #14 |
Rep 472
When I viewed TireRack's comparison videos I really wanted a summer tire that could still have grip/traction off the line in colder to freezing temperatures. I started realizing my tires were wearing faster because they'd always be slipping/spinning when it got colder than 40 degrees.
After learning about the sunflower oil that helps keep traction at low temps this tire seemed and is perfect for my needs. Would I recommend these tires for winter? If you're AWD and you get very very mild winters with less than 2-3 inches of snow you should be fine. If it's anymore if strongly suggest just getting winter tires and good summer tires. They may cost you more but both sets will last much longer and you'll have the best of the summer and best of the winter with 100% confidence. I had to move my car 40 feet from my garage this last winter and my car was slipping and going sideways without even giving any throttle at all I just gave up and waited for it to thaw. |
06-23-2015, 11:37 AM | #15 | ||
Rep 1,126
06-28-2015, 07:37 AM | #16 | |
Rep 66
DC snowstorms as of recent have been more than 3" so I'll keep this in mind if/when I decide to make the switch. There was a good video on Vimeo of a guy driving with the AS3's in his A4 (no issues in the snow but it was mostly plowed during the vid). I'll keep you posted on when I change my LS2's out. |
06-28-2015, 07:40 AM | #17 | |||
Rep 66
