2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum System Voltage question?
      03-01-2016, 04:01 AM   #1
Breach
Drives: F10 520dA M Sport
Hi,
I checked the F10 service menu's System Voltage and observed that:
- Immediately after starting the engine the voltage is 15.0 V
- When I start driving it goes does to 14.8 V on average (fluctuating)
Seems a bit too high to me, but perhaps it is normal? Or do I have a problem with the voltage regulator? Not sure whether the System Voltage is reporting on output from the alternator or after the voltage regulator.
Thanks.
      03-01-2016, 05:36 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
14.8V is in the normal scope of energy management.
Is the battery low and requiring the elevated charge rate?
      03-01-2016, 05:52 PM   #3
Breach
Thanks for the reply. Frankly, I don't know - with ignition on, engine off voltage is around 12.5V (I think maximum is 12.7V?) so I don't think that the battery is low.
What's odd is that immediately after starting the engine (at idle) voltage peaks to 15.0 - 15.1 V which would be above the AGM limit (which I think is at 14.9 V). Curious.
Anyway, yeah, I think everything is as it should be.
