2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Anyone know the process to remove the steering wheel trim piece?
      07-14-2013, 11:45 AM   #1
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
As title states. Im tempted to pry it off as it doesnt look to be really secured by any thing but snap tabs, but just want to be sure before I attempt it.
Referring to this piece:
Any help would be appreciated, thanks guys!
      07-16-2013, 03:49 AM   #2
monogramus
Drives: bmw
You have to unscrew volume/cruise control buttons from behind and pull the trim carefully. You should unplug airbag than it will be easier but unpluging the airbag is dificult
how to remove airbag:
      07-26-2013, 12:01 PM   #3
skydiver22
Drives: 2017 540i
Where did you get this m piece... looking to get one. Also if you have paddle shifters... does it make it harder to remove the volume/cruise modules.
      04-04-2014, 09:55 PM   #4
Ef10
Drives: 2011 BMW 535i
2011 BMW 535i  [10.00]
I bought the OEM M Sport trim piece from my local BMW dealer (Part # 32337841892). I have paddle shifters and the screws in the above video are covered up, so I didn't even attempt to take them off. I did this using a small door panel pry tool. You have to start from the bottom of the steering wheel and work your way up to the top sides. There's no screws, just rubber inserts where the back of the new trim piece fit into. It was challenging without removing the airbag, but the plastic pieces are very forgiving and flexible. I had to very slightly bend a few of the plastic pins in the trim piece to go right into the rubber steering wheel backing.
      04-11-2014, 02:49 PM   #5
skydiver22
Drives: 2017 540i
How much did you pay for the oem sport trim piece???
      11-16-2014, 03:03 AM   #6
TheGlobetrotter
TheGlobetrotter's Avatar
Drives: E92 335i M-Sport
Apparently they are going for about $160. That's pretty hefty for a piece of plastic.
Current: 2012 E92 335
Retired: 2012 F10 535, 2008 E92 335, 2003 E46 330
