2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Radio staying on after engine off
      11-17-2013, 01:36 PM   #1
Piers
Drives: 2017 F10 535d M-Sport
Just picked up my new F10, and have noticed that the radio/media stays on after the engine has been switched off, until I lock the doors?
Is there a way of getting it to turn off with the engine unless I manually turn it back on with the button?
Cheers
      11-17-2013, 01:52 PM   #2
Z4C_luvver
Z4C_luvver's Avatar
Drives: Phoenix Yellow Z4C
Hi Piers, this is normal. I'm not sure if you can easily change it. I found it a bit strange at first, but you quickly become accustomed to it.
Enjoy your F10!!
      11-17-2013, 02:06 PM   #3
Piers
Thanks 5 lover, just seems odd, will have to remember to turn it down!
      11-17-2013, 02:34 PM   #4
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
Do you push the stop button a second time after shutting off the engine?
      11-17-2013, 02:39 PM   #5
Piers
No, should I? Will that not turn the engine back on?
      11-17-2013, 03:00 PM   #6
immx
immx's Avatar
Drives: 2012 520D SE Touring
If you have your foot on the brake (for an auto anyway) yes, if you don't, no it shuts everything off and unlocks the doors.
      11-17-2013, 06:10 PM   #7
lincvert
Drives: M5 wannabe
I find this annoying as well. There should be a way to have the radio turn off with the engine without hitting the button a second time. My car is a manual and if I still have the clutch depressed when hitting the button for the second time, the car will start back up. This should be configurable somehow.
      11-17-2013, 06:27 PM   #8
fung0001
Drives: f10 2013 520i Hartge Tuning
I guess it will turn off after say 10 mins
Let's try
      11-17-2013, 09:01 PM   #9
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
You must either press the start button a second time (foot off the brake OR the clutch), or get out and press the lock button on the key fob or ridges on your door handle (if your car is so equipped), or wait ten minutes, or code your car with this:
- Turn off power (radio and iDrive) when opening door
CAS=>3000=>TC_LOGIC_KLR_OFF_DOOR=>aktiv
Regards,
MWPos
      11-18-2013, 02:43 AM   #10
Piers
Cheers chaps, the second start button push works perfectly, going to use that for the timebeing
andas16.50
      11-18-2013, 03:22 AM   #11
Beancounter_74
Beancounter_74's Avatar
England
602
Drives: M140i F20, 449i F33
So it's not just me who thinks that's a little strange.
I'll try the 'double off' but think I will add this to my list of coding requirements.
      11-18-2013, 09:41 AM   #12
raleedy
Drives: 2016 228i 6-speed
I just lock the doors after a single engine-off button press. Too often if I double press, I find I still have my foot on the brake. Then I feel like I was "punk'd". It's a dumb set-up.
      11-18-2013, 09:42 AM   #13
raleedy
This is not entirely correct -- the standard set-up does not include door unlocks. It doesn't matter whether they were set to lock automatically on driving, or locked manually.
      11-18-2013, 10:11 AM   #14
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
Correct. The door unlock on engine turn off has to be coded in our NA cars.
Regards,
MWPos
      11-18-2013, 06:47 PM   #15
lincvert
Drives: M5 wannabe
Thanks, this alone will make coding worth it for me. I didn't know this was even an option.
      11-19-2013, 01:16 AM   #16
immx
immx's Avatar
Ah! I was basing it on my car, which does unlock the doors on power off. But i am in the UK.
      11-19-2013, 06:58 AM   #17
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
Most coding and mods that I do is from NA envy of EU car defaults!
(Except for that weird right-hand drive thing that you do)
Regards,
MWPos
      11-19-2013, 07:23 AM   #18
Piers
      01-10-2015, 08:13 PM   #19
RPLB530
Drives: 2014 528i xdrive
Agreed!
Silly quirk of the car
      01-26-2015, 06:14 PM   #20
I have the opposite issue. I've spent hours searching the OM and online and I just can't seem to find the answer. How do I turn on the radio without turning on the car. This is my first push button car and I'm used to a key where one gets (usually) acc/off/on/start or off/acc/on/start. When I push the start button (foot off brake) the car is in the "on" function with A/C, lights, fan, etc. energized. I would like to listen to the radio while I'm waiting for my wife at the mall!! TIA!!
      01-26-2015, 07:47 PM   #21
pdrf10
A Man of Wisdumb...
pdrf10's Avatar
Drives: 2011 F10 550i M Sport
Just push the radio button. Be advised, however, that it will turn itself off after ten minutes (or so) to preserve battery life...
      01-26-2015, 08:41 PM   #22
Thanks, but that's not long enough to download a CD.... I need longer run time...
