2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Wheezing noise N20
      06-12-2018, 03:28 PM   #1
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2017 Audi Q7 3.0  [0.00]
2020 M2C  [0.00]
Wheezing noise N20
So, I've noticed an electronic wheezing type noise when I accelerate in the 2012 528i N20. Dont notice it at faster speeds, but a slower speeds, its very evident especially with the windows down.
Anything to be concerned about or is this normal for this car?
      06-14-2018, 08:30 AM   #2
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
It possibly could be that sound. How big of a job is it to get the timing chain guides replaced? Cost? Can a good indy do it?
      06-17-2018, 10:53 AM   #3
Sunny 528i
Drives: 2012 528i
does it sound like this? if so, stop driving the car right away. you need new timing chain guides.
This is highly the timing chain about to blow up your motor. Had the exact same sound and issues on my 2012 528 and the dealer got an approval from Germany to do a full new engine replacement under CPO! I had 74,500 miles on the original motor. They found some scoring in the cylinder walls as well so this helped in swaying towards a new motor. Please go to the dealer ASAP. I was told this is a 10+ hour labor job so my car was at the dealer for over a month
      06-17-2018, 03:31 PM   #4
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
not cheap. I read somewhere $5000, in another thread I read $2000. complain to your dealer and see if they will fix it under warranty. if not getting rid of your car or going to an indy are your only two options.
My car is not under warranty. It is now 6yrs/62k miles. A very reputable indy that I know thinks its belt/pulley related noise and not the timing chain, especially at 62k miles. I'll have it looked at soon.
      06-17-2018, 05:11 PM   #5
woodnook123
Drives: 2016 BMW 535i Xdrive
I too have a 2012 528i with N20 engine. Mine was making same noise, but maybe not quite as bad. Dealer said it was timing chain and guides. After tearing it down, guides were definitely wore. $3600 later, noise was gone. Subsequently got a letter from BMW stating they extended the warranty to 7 yrs/ 70k miles for the timing chain. They reimbursed the cost, so it was covered. Check with dealership. You should be covered! If they give you a hard time, go to another dealer.
      06-17-2018, 05:13 PM   #6
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
BMW has extended the warranty on the N20 for timing chain related issues to 7years/70,000 miles.
      06-18-2018, 04:17 PM   #7
autosyonal
Belgium
9
Drives: f11
2012 320  [0.00]
Hi ,
best to do and easy to do is
Remove the belt start the car if the noise is still there then its probably the timing chain if the noise is gone then you can check all the parts turning with belt on like water pump ,airco pump ,alternator,tensioner, idler , end ........ turn by hand look for play or noise check all parts that are driven by the belt
good luck
grtz
From Belgium
      06-18-2018, 05:07 PM   #8
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
Is this true? Perhaps I go get it looked at at the dealer instead of the indy then. I'll try and wiggle the timing chain a bit in the morning as the engine is too hot right now. Saw that on youtube as a possibility if the chain has stretched
      06-18-2018, 07:53 PM   #9
Stück
Stück's Avatar
Yes.... I've had many clients cars kicked to the dealer for engine noise complaints well outside original warranty and got them fixed free and clear under the extended service action warranty.
      06-19-2018, 09:02 AM   #10
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
Tried to move the timing chain, but it did not budge. Perhaps the timing chain isn't stretched yet, so may be a good time to get it looked over
      06-19-2018, 11:05 AM   #11
miii
Drives: BMW E34
Take it to dealer ASAP - just had mine fixed @65K miles.
Thank you BMW for stepping up and taking care of this issue.
      06-19-2018, 12:36 PM   #12
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
What were your symptoms/sounds? What was fixed/replaced? Thanks
      06-19-2018, 03:08 PM   #13
miii
Drives: BMW E34
Whole bunch of parts - including, timing chain itself, chain tensioner, slide rail, sprocket, chain drive, oil pump drive module and few other related parts.
      11-13-2018, 02:20 PM   #14
MikeBene
Drives: F30 328i N26
Did you find out the reason for this sound?
      11-14-2018, 08:23 AM   #15
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
Yes, I had BMW look at it and they believe it is timing chain related and are applying the SIB to my vehicle. My sound is exactly like the one in the video posted by sunny above. I appreciate BMW stepping up before this causes bigger issues
      12-05-2018, 08:56 PM   #16
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
I just got my car back from BMW after over a week, and happy to report that the whining sounds is gone. Looked under the oil cap and see a new timing chain and guides. Lets hope this puts this issues to rest. Luckily I got this taken care of before the extended warranty expired for me in a few weeks. Thanks BMW for stepping up!
BurrNinja430.50
