2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Stage 2 BMS N63 -Info Please
      04-29-2015, 04:38 PM   #1
///M5Driver
Drives: gaggle of BMW's
Alright so long time tuner here with an AWD dyno that just obtained a Stage 2 N63 piggy back for my own personal car. I'm used to a flash tuning environment, tables, duty cycles, etc so as basic as this device is I'm confused haha.
It looks like there is only 3 or 4 settings you can adjust through the USB interface. Where is everyone starting for reference? What should I look out for other than the obvious knock and lean air fuel mixtures? What sort of target boost are you trying to achieve on 93 octane?
      04-30-2015, 09:40 AM   #2
SteveMD
SteveMD's Avatar
198
Drives: 2016 F10 535i MSport
http://www.n54tech.com/forums/showthread.php?t=22748
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      04-30-2015, 09:54 AM   #3
///M5Driver
Originally Posted by SteveMD View Post
Read that few times... I'm just curious if there is any tricks or better base settings users are at that have had the unit for awhile.
      04-30-2015, 10:23 AM   #4
badblack550xi
badblack550xi's Avatar
Stock setings are fine 2 means mild and 1 means aggressive.. you can keep 93 on aggressive but recommend octane booster for more power.
2011 550i RWD 60-130 7.35
      04-30-2015, 10:24 AM   #5
///M5Driver
Thanks Black
      04-30-2015, 10:24 AM   #6
badblack550xi
Thanks Black
all other settings are useless
      05-06-2015, 09:57 AM   #7
///M5Driver
badblack550xi How did you run your extra wires to the DME without compromising the water tight seal?
      05-14-2015, 09:46 AM   #8
badblack550xi
over the top of wires in rubber seal.
      06-12-2015, 11:16 PM   #9
mikekilpatrick
mikekilpatrick's Avatar
Better way of your water tight seal is to go out about 4 or 5 inches, make a small incision on the top of the cover, slide in the wire harness, and guide it into the compartment. You can then put a piece of duck tape or some other water proof tape if you are worried. But it is far enough from the box to allow any moisture to get to it.
      06-13-2015, 12:18 AM   #10
mikekilpatrick
I took pictures on my entire installation. Just have not put them into an Install document yet. Been very busy with work.
