2010 2011 BMW 5 Series Forum F10 Do You Like The Handling Of Your F10 |
08-08-2017, 08:46 PM | #111 |
Rep 866
I have a lot of experience with great cars to compare to.
1966 912, 1986 CRX Si, 1986 944, 1988 Carrera 3.2 w/sport suspension aligned to Lime Rock, 1991 E30 318is, 1994 Miata SE w/LSD, and a 2005 W211 with so well tuned a suspension, the thing wouldn't slip a tire. Yes the e90 was pretty good for what you could compare it to at the time. Somewhat in the same comfort/handling league as the above. PL |
08-10-2017, 10:37 AM | #112 | |
Rep 112
I also like the Mazda 6 chassis. It's designed for smooth Japanese pavement so the ride is appalling over our horrific GTA roads, but over smooth pavement it rides like no entry-level sedan has a right to. The steering is keen and precise with sharp turn in and it actually transmits some feel! I can't think of any other 2015 model cars with actual steering feel. What do you think of the f10? It's a very nice car for the street, but it's too soft and heavy for aggressive track use. The suspension is soft and the open differential is a real let-down during aggressive cornering, as with many other cars like Mazda. But regardless, as long as I keep the heavy chassis within its paces, I enjoy every second of driving the BMW. |
08-10-2017, 11:30 AM | #113 | |
Rep 891
2021 MBB M5C (retired) 2018 Daytona Violet M3 ZCP (retired), 2016 AW 550i (retired) 2013 EBII 335i (retired), 2008 Platinum Bronze 535xi (retired), 2007 Monaco Blue 335i (retired) 1999 Hellrot M3 coupe (retired) |
08-10-2017, 12:21 PM | #114 | |
Rep 112
it's merely adequate, or "just enough" in terms of output, but 185 ft/lb of torque at 3250RPM is honestly quite impressive especially considering it's just a 4 cylinder. the little 4 banger rips once you get it to 3k rpm and it pulls strong and super linear all the way up to its rev limit. makes a sweet bassy tone while it's at it with lots of induction noise. I've never had a problem with it's power output except on the highway where it feels gutless. but in the city there is enough torque at a pretty low RPM and the gearing makes good advantage of it. it's all about the chassis/handling anyways which overall makes it a very fun car. I do fully agree with you on the mazdaspeed, but apparently they ax'ed the MS brand, but others are saying that they are going to make a mazda speed 3 (2.5 turbo ) 300hp with AWD. easily will top it's class if they make that car. they are also making the next rotary concept, but unfortunately no plans for a mazdaspeed 6. however, they are making a new signature trim level, so the mazda 6 will have a 2.5T like many of us wanted. they will also be using HCCI (essentially compression ignition like a diesel engine, no spark plugs) which increases efficiency by 30%. but more importantly will up torque by 10-30% when paired with a supercharger. so the future looks pretty decent for mazda so far. Last edited by Sumptuous Hummus; 08-10-2017 at 12:33 PM.. |
08-10-2017, 01:58 PM | #115 | |
Rep 891
08-10-2017, 02:44 PM | #116 | |
Rep 112
08-12-2017, 12:53 PM | #117 |
Rep 150
I agree with some folks here that the handling feel of this F10 model sort of replicates the Mercedes. From my experience with my F10 535 M-sport, the suspensions still have too much body-roll when cornering, even on merging freeways ramps and I'm disappointed at that especially with the M-sport package. My 08 Lexus IS has much less body-roll than the 5-ser (I know it's two different cars, but I was expecting something close to that). I have thought about upgrading my sways and/or switching to coilovers, but I would not want to compromise the ride comfort especially when cruising long distance. Secondly, the steering wheels felt heavy at first until I got rid of my run-flats and put regular tires (Yoko's all season; great and very smooth ride). Other than those, I'm very pleased with everything else and I have yet to see the longevity of this beauty.
08-12-2017, 04:43 PM | #118 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
08-12-2017, 05:53 PM | #119 | |
Rep 112
that generation lexus IS has a terribly overdamped suspension. but either way, it's a much lighter and more sporty car then the f10 so it's not really a direct comparison |
08-13-2017, 03:27 PM | #120 |
Rep 866
I have yet to discover a car that handles better with stiffer suspension or less "body lean" as my E30 318is routinely out handled my Carrera 3.2 with sports suspension on country roads.
The luxury suspension that came standard on my E320 CDI was so compliant, I cannot remember its tires ever chirping or the car ever not being sure-footed in normal spirited driving. I don't think this applies to a smooth, curvy track, where a stiffer suspension and less body roll may be an advantage, as my e90 sport would "slide" a bit on corners with as much grace as a dancer or expert skier. So the appeal of stiffening a suspension beyond factory settings isn't all that valuable to me. Tires are a different story. A good LSD would also be welcome. PL |
08-14-2017, 09:13 AM | #121 | |
Rep 14,521
Like Bmw doubles said upgrade to sways and your golden which is what i need to do next!
Sumptuous Hummus18.50 |
