2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wash, Wax, Detailing and Cosmetic protection/repairs Will 343M with more sidewall fit?
      04-01-2020, 11:39 PM   #1
Unspec
Unspec's Avatar
1303
Drives: 2015 BMW 535xi
Just purchased a set of F10 M5 343 wheels for my 535xi. The stock setup is 265/35/20 and 295/30/20. I have xDrive, that already is a no-go. Since I live in northern New Jersey, the roads can get pretty littered with potholes, especially when closer to NYC. If I lower the car on ACS lowering springs, will 255/40/20 and 295/35/20 fit with no rubbing?
2015 BMW 535xi
ISTA VM Setup/Tutorial
      04-02-2020, 02:27 PM   #2
Sylverlee
Drives: White 535i M-Sport, 911 GTS
I doubt it. You have the stock setup on it right now?
      04-02-2020, 02:28 PM   #3
Sylverlee
I've only seen people run 295/30/20 in the back.. and only a select few. I run 285/30/20 on mine right now.. but would like to run 295's as well.
      04-02-2020, 05:40 PM   #4
Sylverlee
btw - anyone with 343's run 10mm spacers in the front?
      04-03-2020, 03:03 PM   #5
Unspec
Unspec's Avatar
1303
Yep, the stock 18 setup. 245/45/18 all around.
2015 BMW 535xi
      04-03-2020, 05:00 PM   #6
Unspec
Unspec's Avatar
1303
Oh wow I posted this in the entirely wrong section didn't I?
2015 BMW 535xi
      08-05-2020, 06:09 AM   #7
slavisavov
slavisavov's Avatar
Bulgaria
Drives: BMW F10 530D X-drive
These are my 343's with 10mm spacers upfront. Tyres are 255/295. The car is lowered with Eibach pro-kit. There's slight rubbing at the back only when going thru large bumps. Other than that overall I'm happy with the setup🤪
Dtex535101.00
Sylverlee150.00
      10-10-2020, 08:11 AM   #8
tungsnp
Drives: BMW 528i
Fit and reasonable ! Can you give me the SP for Eibach lower springs ?
Many thanks !
      02-22-2021, 11:56 AM   #9
slavisavov
slavisavov's Avatar
Bulgaria
Many thanks !
Many thanks !
Sorry just saw your post, somehow I missed it.
Bellow are the specs for the springs:
530d x-drive Part# E10-20-022-02-22
Front Axle load: 1200 kg #112002202VA
Rear Axle load: 1310 kg #112002201HA
