2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Do I have variable dampers?
      11-29-2014, 02:58 PM   #1
makkan00
makkan00's Avatar
Drives: F83 and F36
Sorry but I need to confirm this before I pull the trigger.
I just bought 2011 520d with sports auto transmission.
So it has comfort, normal, sports and sport plus button.
but nothing like comfort plus or eco pro.
Does that mean, my dampers / shocks are standard ones?
I hope they are standard
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      11-29-2014, 03:55 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
Comfort mode at that age indicates VDC is fitted. Still best to use the VIN number in a VIN checker site, to read the full spec'.
BTW, don't you want VDC?
HighlandPete
      11-29-2014, 03:57 PM   #3
makkan00
makkan00's Avatar
Drives: F83 and F36
Vo does not show vdc or anything.
I do not want vdc
Happy with standard suspension so I can work on it with ac schnitzer or eibach springs.
      11-30-2014, 06:25 AM   #4
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
I do not want vdc
You can still change the springs even if the car has vdc.
      11-30-2014, 07:06 AM   #5
valbmw
valbmw's Avatar
94
Drives: 2016 BMW F10 M5 CP 600 hp
BMW like to make simple things very complex. Dampers can be managed separately of transmission depending on what option list you have, the words "adaptive, variable, dynamic" replace each other in different generations and pre- post-restyle models, making even more confusion. I would suggest you take VIN number and find out the option list for better understanding of what exactly you have. The make year 2011 is the pre-restyle one same as mine, so pay attention to this, too.
Variable dampers will not prevent you of using favorite springs, because dampers make the struts stiff-soft while springs make it high-low. No problem here. And for reference you may want to read a couple of threads where experienced members are still discussing BMW terminology linked to your topic:
http://www.bimmerfest.com/forums/sho...d.php?t=652703 and
http://www.bimmerfest.com/forums/sho...d.php?t=642231
      11-30-2014, 12:15 PM   #6
makkan00
makkan00's Avatar
Drives: F83 and F36
Thanks guys.
Collected the car today.
It has normal, sport and sport plus switch only.
And my vo does not suggest anything closer to 'dampers' thingy.
I am on phone so will read the thread later.
Thanks again.
      11-30-2014, 02:19 PM   #7
HighlandPete
Thanks guys.
Thanks again.
Definitely sorted... no VDC.
Keep us posted on your opinions of the car.
HighlandPete
      11-30-2014, 02:41 PM   #8
makkan00
makkan00's Avatar
Drives: F83 and F36
HighlandPete
Thanks for confirmation. I have ordered Eibach pro springs after reading plenty of threads on ACS, Eibach and HR.
As some of us have moved from E9x platform and we all had 6 pots at some stage (so some of you still have 6 pot F1X). But here is my initial impression about F10 520d.
-Its miles ahead of 320d. There is no comparison of two cars. 520d is refined, quiet and build quality is at another level.
-I had 330d remapped. So, 520d is bit flat and dull UNLESS you click sport / sport plus and move the shifter to sports mode. It does transform the car (as you mentioned earlier). Car becomes more responsive and car is totally different animal. Honestly, I did not feel that I was driving 4 cylinder diesel car.
-8 speed sports auto is MUST IMHO in these cars. What a brilliant kit and car becomes so smooth.
- It is very economical. Car had half tank and I have done 200 plus miles and trip meter is showing 175 miles remaining. I think realistically, I can get 500miles per tank if its mostly motorway driving.
-Exterior is very subtle and most 3 series and other drivers take 5 series bit easy. I have some cosmetic modifications planned for my car to give it aggressive look (some may not like those).
I am looking for 20 inch wheels for 5 series and struggling to find a decent pair. Anything decent is 1000 plus
Thanks to all of you who helped me to choose the right car.
      12-01-2014, 06:12 AM   #9
makkan00
makkan00's Avatar
Drives: F83 and F36
Guys
Are there any forums where I can see what is 'for sale'?
Something like what we have 'classified section' on 3 series forums.
      12-01-2014, 06:20 AM   #10
valbmw
valbmw's Avatar
94
Guys
Please have a look at this one for owners: http://f10.5post.com/forums/forumdisplay.php?f=315
And another one for commercials: http://f10.5post.com/forums/forumdisplay.php?f=357
      12-01-2014, 11:19 AM   #11
SpeedTrip
SpeedTrip's Avatar
England
26
Drives: F21 M140i LCI-2 Alpine
Any good - maybe too cheap ..... ?
http://www.ebay.co.uk/itm/20-034-X4-...p2054897.l4275
M140i LCI-2 is the 16th BMW since 1977 ....
320i *2, 323i, 520i *2, 540i, 535i, 840i, E36 M5, 328i, 530i, 320d, 535d, M135i, M140i * 2
      12-01-2014, 12:40 PM   #12
Beancounter_74
Beancounter_74's Avatar
England
602
Drives: M140i F20, 449i F33
If it's mostly motorway driving and your staying below license losing territory, you'll get 700+ out of the tank as long as you don't bury the throttle at every opportunity. I've just ticked over 26k in my first year, mostly motorways and I generally see between 650 and 750 a tank
      12-01-2014, 02:31 PM   #13
Fox530
Drives: M340i xDrive
Of course it is - the tyres alone cost that. You are not going to find a decent set of quality 20" wheels and half decent tyres for 'cheap'.
      12-01-2014, 02:58 PM   #14
The Beast
The Beast's Avatar
Drives: VW Transporter Sportline
+1
Your looking at a minimum of £2k for a decent set of wheels and tyres, more if you stick to run flats. Don't bother with cheap 20" wheels, you might be able to get away with 18" cheap wheels but at 20" they will crack... a few of my friends learnt this at considerable cost
      12-01-2014, 05:35 PM   #15
makkan00
makkan00's Avatar
Drives: F83 and F36
Thanks mate.
Getting wheels from the other side of ponds is pain in the bottom.
I will have to find uk distributor.
      12-01-2014, 05:36 PM   #16
makkan00
makkan00's Avatar
Drives: F83 and F36
Originally Posted by SpeedTrip View Post
Thanks mate. Appreciate your link. I do not like M5/ M6 wheels in this shape. Going to put the wheels at the end of this thread to ask opinions of others.
      12-01-2014, 05:45 PM   #17
makkan00
makkan00's Avatar
Drives: F83 and F36
I was getting 400-450 out of remapped 330d.
I travel on m25 most of the time and traffic is variable and hence MPG can vary depending on the traffic. If I get 600miles per tank, I will be more than happy.
I should have used 'wheels only' word.
Anything which is decent is nearly a grand. I have not looked at the rubber yet as that would be next target. Summer is far away so I can get 'half decent' rubber in time.
Originally Posted by The Beast View Post
+1
Hmmm interesting. I had Ispiri ISR10 on my 330d and they were 19.
I will stick with CM wheels as they sell quality wheels.
Shortlisted wheels so far:
M359
or
OEMS Stance SC7
Now my car is Grey so I will have to stick with silver colour.
Thanks.
      12-02-2014, 01:19 AM   #18
The Beast
The Beast's Avatar
M359 for me
      12-02-2014, 05:09 AM   #19
valbmw
valbmw's Avatar
94
Looking at the AG M359 I would recommend to also have a look at the VMR wheels http://www.velocitymotoring.com/vmr-wheels/ as having quite similar classic designs in their collection, comparable quality and close price tag. And a couple of shops in your area http://www.ca-automotive.co.uk/installers.html.
Hope, more choice is better
