2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications BootMod3 N55
      11-08-2018, 06:36 PM   #1
iRoik
Australia
Drives: F10 535i
2012 BMW 535i  [0.00]
BootMod3 N55
Hey guys, hoping for a bit of help here. The BootMod3 support is great but due to time zone differences (I’m in Australia) we can only exchange one message per day 😞.
Anyway, so I bought a BM3 license and managed to flash my car successfully. At first the DME wasn’t supported but the BM3 guys fixed that up for me by sending me a new coding file. Flashing failed the first few times, and the car wouldn’t start so I went to get a battery charger which fixed it. I was then able to fix most of the errors via the online coding function.
There are several issues (and hopefully not more undiscovered ones) that I cannot get rid of, and hoping you guys can shed some light on this for me:
  • Cannot change driving modes (Comfort, Sport, Sport+) unless I am under 20km/h
  • Cruise control not working
  • Auto Hold not working
  • Stop/Start not working
  • DSC failure
The Online Coding has not fixed these issues.
2012 F10 535i
N55 OTS Stage 1, 91 Oct
Thanks in advance!
      11-08-2018, 06:57 PM   #2
AZ-MCRacer
AZ-MCRacer's Avatar
306
Drives: 2022 G82 M4, 2013 F10 N55
Did you try flashing back to stock, making sure those things work again, and then re-flash Stage 1?
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD!
1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped
      11-09-2018, 03:20 PM   #3
iRoik
Australia
Drives: F10 535i
Yep, but unfortunately still no luck. Even on the stock map, those functions still don't work. I've also tried clearing codes and disconnecting the battery for 15 minutes. proTUNING Freaks replied to my ticket and said they will likely need to remote in to help me fix it. Waiting for them to reply and schedule a time with me, hopefully sooner rather than later
Kudos to them for fast replies, but the timezone difference means their 9am-5pm support hours are 1am-9am my local time.
      11-12-2018, 10:30 PM   #4
LucasM3
Drives: E92 M3
Let us know if that was fixed. I'm debating between MHD and BOTMOD3 for my 535
      11-13-2018, 01:42 AM   #5
anthonygan
Drives: 2015 BMW 535i XDrive
Literally me too, I’m debating between the both!!!! Ugh
      11-13-2018, 08:50 AM   #6
robbiss7
Drives: E90 LCI, F10 LCI
I debated between BM3 and MHD. Chose BM3
Just installed the BM3 last night with no problems. Flashed the car in less than 20 minutes.
      11-13-2018, 02:29 PM   #7
Shieldze1025
Keepin' America Free
Shieldze1025's Avatar
Drives: F10 535i
I have a 2012 535i as well, I have not had any of those issues with BM3. Good luck OP, keep us posted.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough"
-Mario Andretti
      11-16-2018, 07:21 PM   #8
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Good luck OP
https://x-ph.com/sale/
Phone number 702-494-9435
      11-26-2018, 06:48 PM   #9
iRoik
Australia
Drives: F10 535i
Sorry, I've been away. I manged to get it all sorted. Due to time zone differences it was hard to catch them for the remote session, so I just found a DIY and did it myself. Used ESYS to update every module in the car, and then tried flashing again.
Worked great with no errors. However, I was getting low-RPM surges, and on top of that, not much power low down. Decided to flash to stock and back again, but this time it seems as though the flash didn't stick? Low RPM surges are gone but it feels like the car is stock.
I'll try again over the next few days, otherwise I'll sort it out when I'm back from my upcoming holiday
      11-26-2018, 09:00 PM   #10
LucasM3
Drives: E92 M3
What do you guys prefer to flash your car, laptop or phone /
      11-26-2018, 09:33 PM   #11
iRoik
Australia
Drives: F10 535i
Phone would be more convenient, but not necessary (you need to purchase an additional adapter). I already had an E-Net cable from coding so didn't see the value. Unless you're going to be data logging or switching maps a lot, I would go with the laptop.
      11-26-2018, 10:07 PM   #12
LucasM3
Drives: E92 M3
So I would need to have that cable
I already have this one that i was using to for MHDflash for my former 335
and this one
Both work just fine, are they going to work for bootmod3 ?
      11-26-2018, 10:39 PM   #13
iRoik
Australia
Drives: F10 535i
and this one
Whether by phone or by laptop, you would need the top cable (ENET) as F series vehicles communicate differently to E series.
Previously I had the same white cable that you had (KDAN) for coding my E90, but it was not compatible with my F10 (you can make it compatible by assigning an IP to the USB connection I think - there are guides somewhere, but I found it easier just to buy an ENET cable).
mike@x-ph.com includes a free ENET cable with BootMod3 sales.
As for the Wifi/Bluetooth adapter you already have, I believe that cannot be used as the BootMod3 agent is actually just a wireless hotspot adapter. The connection would still be ENET cable -> Wireless Agent (powered by USB) -> Phone. I have not used the Wireless Agent before, so someone please correct me if I'm wrong. Just basing this on my understanding of what the agent does.
If you're feeling up to it, you can try make your own Wireless Agent following this DIY:
https://f30.bimmerpost.com/forums/sh....php?t=1484555
      11-27-2018, 10:19 PM   #14
LucasM3
Drives: E92 M3
Thanks for the write up
      11-30-2018, 01:10 PM   #15
Shieldze1025
Drives: F10 535i
That's good to hear. I too have the low RPM surges at cold start up. I raised the idle RPM to 950 I think and they're a lot better, but still there. Guess BMW has that cold start annoyance for a reason. I'm going to change my idle RPM to 1050 and see if that helps.
Other than that I've enjoyed mine, haven't had too many issues.
-Mario Andretti
