2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Transmission fluid change
      03-02-2020, 01:10 PM   #1
David_Vasha
David_Vasha's Avatar
Drives: 2011 535i XDrive
Is it a good idea to change my tranny fluid at 105,000? I have a BMW f10 535xi and I don't know if it's ever been changed before.
      03-02-2020, 01:53 PM   #2
Wht550jersey
Drives: 2011 550i
You can buy the filter kit , I know a lot of people change it around 80k , even tho bmw says lifetime
      03-02-2020, 02:37 PM   #3
95blkmax
Drives: '11 535 M-Sport
Just last week I changed my trans fluid, and I just broke into 112k miles.
Original fluid in there. It was very dark but was not burnt-smelling at all. I checked the magnets in the old trans pan and they barely had a thin coating of dust on them. So thankfully the wear was very minimal.
I used the ZF 8HP service kit from FCP Euro, using the ZF filter and Liqui Moli fluid and it's working great (it was like $144). It came with 7 liters but I only used like 3.5. In day to day driving I can't tell the difference. In WOT pulls it shifts a tad faster. I'm happy with it.
Anywho, when I started draining it I figured I'd collect it in a clean container. I was basically checking that it didn't smell burnt and the magnets weren't full of crud. Had this been the case I would have just pumped the old fluid back in and mounted the old filter pan. But once I noticed it smelled like normal fluid (just dark), and the magnets had minimal matter on them, I went ahead and changed it.
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24
      03-02-2020, 02:46 PM   #4
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
Very good idea. Pretty easy and straight forward. Do yourself a favor and buy or make a power filler, it makes the whole job a lot less messy. You can DIY a power filler for 20 bucks.
Don't undo the drain hole until you've loosened the fill port. Use a long arm 8mm allen key for it, the one Husky makes is the one I used. Pickup a 8mm and 9mm ratcheting box wrench, you'll need to remove two small metal shields that prevent access to the fill nut. Observe proper tightening pattern.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      03-02-2020, 02:56 PM   #5
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
I would change it only if you plan on keeping the car long term. If you plan to sell within a few years and the trans is ok just leave it alone.
      03-02-2020, 02:57 PM   #6
OnlyGerman
OnlyGerman's Avatar
Best to use ZF Fluid.. you only do it once.
      03-02-2020, 03:13 PM   #7
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
is there a DIY on this guys?
      03-02-2020, 03:16 PM   #8
95blkmax
I was of this train of thought as well. But after researching Liqui Moli in particular I found tons of folks using it on their 8HPs if various platforms (BMW and Audi alike) and people are very happy with it. I still agree with you that if you want that peace of mind then yes, go ahead and get the ZF stuff. But for me, I felt comfortable after the research I did on it to use LM fluid
      03-02-2020, 03:43 PM   #9
David_Vasha
My independent mechanic uses liqui moly top tec 1800 for their fluid. They've been doing a lot of tranny fluid changes with that fluid but idk I am so on the fence on either zf or top tec. Honestly, is there really a difference?
      03-02-2020, 04:37 PM   #10
Unspec
Unspec's Avatar
1301
I'm about to do it again this Friday, I'll document the process
2015 BMW 535xi
      03-02-2020, 04:39 PM   #11
95blkmax
I guess time will tell! Folks are saying that it's working perfectly fine for a while. Me, I only have about 70 miles on it so far having tested in traffic, cruising and WOT pulls. Transmission seems to be happy. I'll report back once I get another 500 miles. With transmissions if they act right after that much with new fluid, it's TYPICALLY good to go
      03-02-2020, 06:31 PM   #12
lsturbointeg
photos would be awesome bro!
      03-03-2020, 06:38 AM   #13
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
A whole collection of stuff linked and attached.
My recommendations -
use ISTA, don't reset adaptations, use ZF fluid (since you're mixing in half of the existing and the price is not outrageous from FCP), have a helper, changing the filter is just as important as changing the fluid - especially the first time.
ZF recommends changing fluild and filter every 100,000km (60k miles).
https://blog.fcpeuro.com/how-to-serv...p-transmission
(ISTA) Transmission control unit - oil level adjustment.pdf
2015_8HP_alle_Oelbefuellvorschrift_EN.pdf
ZF_SI_Oelwechselkit_8HP (50130 EN 04.2016).pdf
xHP - Adaptations.pdf
OrcaPod73.50
      03-03-2020, 07:59 AM   #14
David_Vasha
What does ISTA do? I saw a video on the ZF beginners doing a fluid change and they didn't use ista?
      03-03-2020, 08:09 AM   #15
Surly73
Read the doc with ISTA in the title. It says it all.
https://f10.5post.com/forums/attachm...4&d=1583239004
      03-03-2020, 08:37 AM   #16
Unspec
Unspec's Avatar
1301
You don't 100% need ISTA. Primarily useful for reading transmission fluid temp, since you need to top off when the fluid has reached a certain temp, but if you have something else that can read the temp it's fine as well.
2015 BMW 535xi
      03-03-2020, 09:28 AM   #17
Wht550jersey
Drives: 2011 550i
Great info
      03-03-2020, 03:55 PM   #18
Surly73
Agreed - there are other test sets that can read transmission temp. Conveniently ISTA also walks you through the process at each click too (gear selection, top up etc...)
      03-04-2020, 08:15 AM   #19
Trainwreck914
Trainwreck914's Avatar
Drives: BMW F10 F15 E39 E90 E53
Subscribed
      03-04-2020, 08:26 AM   #20
Wht550jersey
Drives: 2011 550i
I just bought the kit from fcp euro hopefully get this done next weekend
      04-02-2020, 09:37 PM   #21
BurrNinja
Torque pro gives transmission temp reading for those who can spend 5$ and dont have access to a laptop with software on it.
Instgram @burninja
      04-03-2020, 11:31 PM   #22
BurrNinja
Just changed transmission pan and fluid, at 100,854 miles. Fluid was getting dark, dusting of metal on magnets and filter was dark. Used FCPeuro Liquimoly fluid and pan. Its a night and day difference. Glad I did it now then waiting to long.
