2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Coding in SOCAL
      05-18-2014, 10:26 PM   #1
mge92
SPEED RACER
mge92's Avatar
Drives: BMW X5 M50d BMW M2 CS
Coding in SOCAL
I am out in Santa Barbara till the 28th if anyone wants their car coded. Msg me on the forums or at DC BMW CODING @ GMAIL.COM (no spaces)
      05-19-2014, 02:17 PM   #2
MotormanDan
Motorman at MTA NYC Transit
MotormanDan's Avatar
Drives: 2011 535i Xdrive
Just curios, what does this "coding" do?
      05-19-2014, 03:14 PM   #3
gtmassive75
gtmassive75's Avatar
361
Drives: G05 X5,G20 M340,Infiniti Q50RS
Just a few.. Close side mirrors when press lock on key fob/ dvd in motion/ tire pressure on screen/ disable Auto Start Stop.
2020 G05 MSport 40i--Phytonic Blue Metallic/Vernasca Coffee Leather/Multi Contour SeatsTrim/Executive Package/MSport Brakes/Icon Adaptive Led HeadlightsW/Laserlight/Harman Kardon/Heated Front Seats Armrests & Steering
      05-19-2014, 06:32 PM   #4
e60rocks
Drives: 07 E60
Can this be done remotely? I'm in minnespolis
      05-25-2014, 10:36 PM   #5
mge92
SPEED RACER
mge92's Avatar
Unfortunately I cannot remotely code since I do not have the hardware to do so but if you go to Codemycar.com Okee can certainly help you out. Hope that helps.
      05-30-2014, 04:10 AM   #6
Chuck W.
Chuck W.'s Avatar
356
Drives: '95 Porsche 993 Cab
Here are some of the neat things it can do;
Close mirrors + windows + sunroof through Comfort Access - closing works by holding finger on groves area on handle
Close/ open mirrors + windows + sunroof through Key Fob - hold down open or close key
Mirrors (un)fold automatically when (un)lock via FOB or comfort access + reduced folding delay to 0 second
Removed front windows roll-up interruption when door is opened
Removed legal disclaimers
Turned off headlights side amber LEDs
Tail lights on with DRL
Fog lights stay on with high beams
Tilt passenger further down when reverse gear is engaged (mirror selector must be in left position)
Close trunk from driver side button + FOB
DVD in motion
PSI/ Temp readings
Movie playback from USB port in armrest compartment, support for .avi, .mp4 + .ogg .vcd .xvid
Increased rain sensor sensitivity for Auto Wipers (all 3 positions)
Rear, top-view and side cams on while driving
Removed rear windows roll-up interruption
And, it can be done remotely.
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's
1995 Porsche 993 Cab - Mine
2001 Toyota Tundra SR5 Ext Cab - Hay Hauler
      05-30-2014, 11:38 PM   #7
BMPOWERED
BMPOWERED's Avatar
65
Drives: 2014 650 GC M sport
DVD in motion
PSI/ Temp readings
I had my F10 coded and two of the mentioned options would not work on my car. I am wondering if that is common:
1. PSI readings would not show in I drive. After being coded, I only see 2 dashes where the PSI should be. (Yes my sensors are working) - I was told this is a common issue on some cars.
2. I was told remote trunk close does not work because I don't have the automatic trunk close feature. (In stock form, the trunk opening is powered)
My car is a 2011 550i Msport w/P1, P2, no comfort access, built December 2010
2014 BMW 650GC M sport
2011 BMW 550i M-sport/AW
1991 Nissan 300ZX Twin Turbo
2007 Chevrolet Corvette Z51 (sold)
2001 BMW 325ci (sold)
      05-31-2014, 01:06 AM   #8
MotormanDan
DVD in motion
PSI/ Temp readings
How is that done remotely?
      05-31-2014, 10:24 AM   #9
Chuck W.
Chuck W.'s Avatar
356
Sounds right. I had my F10 coded and had the PSI reading along with the temp. Then had the global update and I could not get it back.
There is another BMW forum that can explain it and direct you to members that can do it for you.
2022 X5 40I - Ours
      01-17-2015, 01:17 PM   #10
c21sam
Drives: 2018 BMW 530e Xdrive
There is a guy in Fontana that coded mine. He was very good and reasonable. You can find him by typing BMW coding on Craiglist in the Inland Empire.
