2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Quickjack 5000slx
      03-06-2019, 08:12 PM   #1
CC424
Drives: 2014 535i M Sport
Ordered the qj but not sure if it fits my 14 535i m-sport... anyone else using this?
      03-06-2019, 11:22 PM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
interested in how this works out for you. I see people on YouTube use them a lot
      03-06-2019, 11:24 PM   #3
CC424
I just put it together and will test it out tomorrow. Assembly didn't take that long. I'm just worried it won't reach the jack points and I mess something up. May have to get the extension rails. They are about 200 more. I'm going to use the lift to install H&r springs.
      03-07-2019, 01:04 PM   #4
reihensechser
reihensechser's Avatar
Germany
35
Drives: 2016 550i XDrive
i have the quickjack 5000ext...works awesome
      03-07-2019, 06:44 PM   #5
CC424
Fell a little short of the jack points. The passenger side is solid on the frames. Drivers side is a little sketch.
Thinking about ordering the extend plates but I could get my downpipe instead... decisions!!!
      03-07-2019, 10:52 PM   #6
lsturbointeg
how much clearance do you need for that to work? my car sits pretty low!
      03-08-2019, 12:26 AM   #7
CC424
[img]
View post on imgur.com
[/img]
I'm good with the clearance. The extensions are to make sure the car is supported by the jacks. They extend the arms to meet the jack points.
Btw... sweet ride, looks awesome!
      03-08-2019, 01:28 AM   #8
svt1998gt
Drives: 2008 e90 335i, 2012 X5 M spor
Same here i am on kwv3 and sit really low...any clearance issues?
      03-08-2019, 07:47 AM   #9
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Com on man you know you won't clear too low
      03-08-2019, 07:51 AM   #10
lsturbointeg
LOL I had to try
      03-09-2019, 10:50 PM   #11
spyroz
spyroz's Avatar
Drives: BMW f10 550i ///M Sport
LOL I had to try
come to texas meet buddy...
BMW f10 550i Msport
      03-10-2019, 11:05 AM   #12
Luky
Luky's Avatar
Drives: 2016 550i M Sport
I have had the quickjack 7000SLX for 3 or 4 years. They did not have the ext versions when I bought it. It is a little short for F10 jack points but they have newer longer versions so get one that will fit you car (but may not fit a smaller car or spouses car in the future). I lay a 2x8 across the top to extend it to the jack points and it works fine. After I put H&R race springs on my 535i this made it too low to fit the QJ7000 and 2x8 board so I had to put spacers under front wheels first to lift it (two pieces of 2x8 stacked and screwed together) before I used the QJ. If you have ramps would probably work to raise car enough for QJ to fit. Raises car enough to do trans pan/fluid, sway bars and probably exhaust work. A little bit of a pain getting it all lined up but then 60 seconds and it is up. I usually have my son do one side while I line up the other and in about 5-10 min have it up it the air (includes hooking up hoses). It has been a good investment. Hoses can be hard to connect as they have fluid/pressure in them. I have found pressing the down button while hooking to the pump (first) helps relieve this then hook to the jacks (have someone hold button).
Another thing is a lot of places selling them now and all probably have same price. Shipping was included when I bought so I got from out of state vendor that didn't charge Commiefornia sales tax but it still shipped direct from QJ warehouse in CA.
Just went and measured. F10 jack points are 64" from outside ends of the rectangular blocks. (The QJ SLX is only 60" long but the newer EXT vesions should fit fine at 66"). You may want to get some BMW jack pad adapters to put on top of the rubber blocks.
      03-10-2019, 11:12 AM   #13
CC424
Got mine from Costco hell of a deal.... $999 + tax free shipping
      03-10-2019, 11:38 AM   #14
Luky
Luky's Avatar
Which version? My QJ7000SLX was a like $1300 when I got it years ago and there were no discounts back then. I got the bigger one to be able to do SUV and trucks too. Sounds like you got a good deal.
      03-10-2019, 11:42 AM   #15
Luky
Luky's Avatar
Get a pair of 2x8 x70" or 2x10 x 70" and lay on top of the QJ. See my earlier post.
CC42426.50
      03-10-2019, 11:42 AM   #16
CC424
I got the 5000 because I want to use it for a motorcycle lift too. I have 2018 Roadglide. I wish I had the lift when I was modding it. But it should come in handy for oil changes.
      03-10-2019, 11:47 AM   #17
Luky
Luky's Avatar
Yeah I hear you. I saw that last year and thought about buying the MC adapter for my BMW R1100RT. But my neighbor has the harbor freight MC lift and I just go down and borrow it (has wheels on one end to roll it) when I need to work on my bike. It's cheaper.
      03-10-2019, 11:36 PM   #18
lsturbointeg
does this take up space in the garage? are you guys able to close it up and put it somewhere?
      03-11-2019, 10:37 PM   #19
Luky
Luky's Avatar
They now sell "hanger" mounts you can put on your wall to get them out of the way. I just push them together and slide towards the rear of my garage, then back in over them so they are under the car.
      03-31-2019, 11:10 PM   #20
Luky
Luky's Avatar
So I built some extension boards yesterday for my QJ. I got a 2x10 x 12' long cut into two 70" lengths ($13 homedepot) then ripped the width to 8.5" with my circular saw. I added a "pad" of 3/16" 70 Shore A hard neoprene sheet I got off amazon. The 36" x 12" rubber was $30. Could probably use 1/16" or 1/8" ok too. I cut it into four 8.5" x 12" pads and used four 1" drywall screws with small washers on each corner of each pad to hold it in place.
Worked pretty well today. The plank on top of the QJ just barely fit under the car with the Msport suspension so if you are lowered you would have to use a floor Jack to raise it first to put boards under the front tires like 2x10 or similar so the QJ and extended board will fit under the jacking points on the sides. I got the QJ and plank in position then lifted the wheels off the ground and set it back down. The change in wheel angles gave enough "lift" room to easily realign the plank to be more centered then I raised it all the way up again to pull a front caliper off (measuring for a brake upgrade). Will try to post some pics.
      03-31-2019, 11:56 PM   #21
Luky
Luky's Avatar
https://photos.app.goo.gl/M8nhBFvdE2rVurR48
https://photos.app.goo.gl/3E6RqXrq8JAtQeuj9
https://photos.app.goo.gl/2AraqZ8bsb3ZZypi7
