2010 2011 BMW 5 Series Forum F10 Oil Filter Housing Gasket (Help) |
11-25-2019, 07:02 PM | #1 |
Rep 2,197
Can someone confirm for me that this is indeed a leaky oil filter housing gasket (OFHG)? If so, what should I expect to pay an indy to get this replaced? Thanks in advance!
Bake
11-27-2019, 10:24 AM | #3 |
Rep 79
Its hard to tell because that can be just residue coming from changing filters.
You can see from the bottom housing though. If there is more oil near the coolant pipes. If you really want to be sure. Spray it down with brake or maf cleaner. And check in a few days. Last edited by mashpotato; 11-27-2019 at 10:36 AM.. |
12-02-2019, 12:55 AM | #4 |
Rep 35
Replaced mine as soon as I bought the car last month. Rock auto had the mahle set (both gaskets)
Apparently they’re out of stock but FCPEURO has it https://www.fcpeuro.com/BMW-parts/53...&b=5&d=3584&v= I replaced just the gaskets and it’s been fine, per my friend that’s a master bmw tech |
12-02-2019, 10:17 PM | #5 |
Rep 205
Mashpotato is right. Clean the area but be sure to not get cleaner (if you use any) on the belts as it can deteriorate the belt some. At least, that's what happened to mine.
It's not hard to change out yourself. Take your time and don't overtorque and it shouldn't take more than 1hr first time around. Order from FCPEuro as they have the lifetime warranty. |
12-03-2019, 05:38 AM | #6 |
Rep 1,564
Do a search on OFHG engine failure.....scary stuff....make sure you read up on the oil priming procedure which is basically: pull the injector connectors, crank engine 10 seconds, wait 20 seconds, crank 10 seconds and repeat procedure two more times. If it were me I would go one step further and hook up a oil pressure gauge or at least something that will read th oil pressure from the ob2. To many horror stories out there....
12-19-2019, 07:09 AM | #7 |
Rep 17
I just replaced both of my gaskets replaced at an indy shop. They had to change my oil as well because coolant got in it. Total was about $600.
12-20-2019, 03:00 PM | #8 |
Rep 53
Wow - for like $90 in parts and and two hours of labor.
2016 528iXDrive
1988 Carrera Coupe |
EL Jeffe 5612.50 |
12-20-2019, 05:27 PM | #9 |
Rep 5,378
12-21-2019, 08:44 AM | #10 |
Rep 53
Sorry - you’re right. I did not mean to come off as an a$$.
2016 528iXDrive
12-21-2019, 12:06 PM | #11 |
Rep 14,521
I was gonna try to attempt to do this myself as watching the YouTube video made it look easy but they did show a couple of things that would be a PITA so I decided to support my local Indy shop do it so I can spend money at the mall
06-26-2020, 10:38 AM | #12 |
Rep 30
definately leaking...did you ever get it fixed? this can cause you more issues...talking with personal experience. let me know if you want to do it your self and i can share my video with you.
06-26-2020, 07:37 PM | #14 |
Rep 915
With that much puddled in the area it looks like a oil change job and missed cleaning it all.
Instgram @burninja
06-26-2020, 09:24 PM | #15 |
Rep 2,197
So ironic that this thread got bumped today. The leak turned out to be a bad oil filter O-ring. Replaced it and it stopped leaking, however I did just have the OFHG, water pump, thermostat, tensioner, belt, etc all replaced today as preventative maintenance. Bought all of the parts about 5 months ago and they have been sitting in the garage since because I was super busy at work and then Covid hit and I wasn't really in a rush as I have been WFH and barely driving the car.
Bake
BurrNinja430.50 |
06-27-2020, 11:23 AM | #16 |
Rep 57
that’s great buddy
Same here: i still have a Vaico-Valvecover for my N55 F10. It’s almost 1 year now. I think i replace it tomorrow. Just because i love working on cars. im not sure if i do a tutorial... what do you guys think? |
06-27-2020, 04:37 PM | #17 | |
Rep 30
I Just got done with my valve cover today...I made a video..will try to edit and post today. hope it helps you...it turned out to be easier than i thought. just an advise Use BMW OEM gasket (made my MAHLE)..atleast you will know it will last you 50k plus miles....the other after market brands i have heard horror stories about that it lasts no more than 10-20k and leaks.... |
06-27-2020, 05:14 PM | #18 |
Rep 57
yeah you’re absolutely right. Never cheap out on important parts.
I bought the whole valve cover (from VAICO) and i still have a genuine OE VCG. The hesitation has gotten much better; but it is still there. I hope its the pcv |
06-28-2020, 02:54 PM | #19 |
Rep 30
OK so finally did mine successfully.
here is a video of the valve cover gasket and oil filter housing assembly gasket replacement in as much detail as i could cover doing it all by myself. Cant wait for my son to grow up and help me lol. Oil Filter housing assembly Valve cover gasket replacement |
Sylverlee150.00 |
07-03-2020, 07:02 AM | #21 |
Rep 1,261
Well damn wanna come do mine?
