2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Vorstiener front splitter
      09-05-2015, 10:27 AM   #1
Alcenos
Field Marshal 🔱
Alcenos's Avatar
Drives: 2019 M5 Competition (F90)
I tried searching the forums for a DIY on installing a Vorstiener front splitter/spoiler but cannot seem to find one. I would think that it would be easy, but did not want to take any chances.
Also has anyone painted a polyurethane splitter? Yes, I am considering one of the knock-offs on eBay. I don't like the carbon fiber look and want it to match the rest of my jet black car.
2019 F90 M5 Competition - Black Sapphire Metallic
2015 F10 535i xDrive M-Sport - Jet Black (retired)
2008 E60 528i - Space Grey (retired)
2002 E46 325i - Space Grey (retired)
1999 E46 328i - Orient Blue (retired)
      12-22-2015, 08:16 AM   #2
Alcenos
Field Marshal 🔱
Alcenos's Avatar
Are there any good DIYs out there for attaching a front splitter? I have heard that the 3M tape does nothing and screws should be used.
      01-02-2016, 05:53 PM   #3
Akkord29
Drives: F80, G20, E46
my real lip had some predrilled type holes on the bottom of the lip which I bought some screws from home depot and tapped into the bumper. I'll assume the fake ones will have something similar. one on each side and two towards the middle.
      01-02-2016, 07:03 PM   #4
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
I did not paint my PU splitter as it's a matte black finish but I did you bolts/polyplene washers and nuts to hold it up. No double sided tape used except on the frint lip I'm probably gonna move it back 1.5"
      01-03-2016, 07:37 AM   #5
Alcenos
Field Marshal 🔱
Alcenos's Avatar
Thanks for the words of wisdom. I did finally order it yesterday, so in a few weeks, weather permitting, I'll be able to provide some feedback.
      01-09-2016, 06:52 AM   #6
Alcenos
Field Marshal 🔱
Alcenos's Avatar
Well, My splitter arrived yesterday. Doing a dry run, the fitment looks pretty good. It only has 2 screw holes/tabs on the ends, so I will need to figure out what to do for the middle. From other posts that I read, using 3M tape will not hold up to the down force generated when driving. Maybe some self tapping screws would do the trick. It does definitely need to be painted to get the right look, but I'm also considering vinyl wrapping it. The 3M gloss black that I used f the door handle inserts and side markers matches Jet Black pretty good. The vinyl may also give and added layer of protection if and when I bottom it out.
      01-09-2016, 01:35 PM   #7
Diesel Flash
The Flasher
Diesel Flash's Avatar
Drives: F11 520d M sport
2008 320d  [0.00]
I fixed my vorsteiner rep splitter with just self tappers, had to pre drill holes though, from memory think i drove 6 screws underneath thats all
BMW F11 520d M-Sport, Stage2 Remap, Sophisto Grau, Oyster leather, Pro Nav, 20" M5 reps, H&R Sport Springs, Vorsteiner Rep Front&Rear Carbon valance, Quad exhaust Conversion, M5 Grill, Focal Audio
      01-09-2016, 02:45 PM   #8
Alcenos
Field Marshal 🔱
Alcenos's Avatar
Thanks for the advice. In what locations did you drive the screws?
      01-10-2016, 08:47 AM   #9
Diesel Flash
The Flasher
2008 320d  [0.00]
here are the screws and the locations, I did pilot hole everything aswell, my splitter also came with 4 or 5 tabs which I also drilled and screwed with the larger self tappers. the smaller screws were just overkill but ithought better safe than sorry.
no double sided tape or bond used at all. hope this helps.
      01-10-2016, 10:22 AM   #10
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
good job.
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      01-10-2016, 05:25 PM   #11
lsturbointeg
gotta love DIY's!
      01-29-2016, 09:17 AM   #12
valbmw
valbmw's Avatar
94
Drives: 2016 BMW F10 M5 CP 600 hp
Vorsteiner front splitter
Hi guys. Here are my two cents.
The splitter has 4 holes (see pics) that fit the bolts that hold the M Tech front bumper.
Never used the 3M tapes for my carbon fiber pieces (just don't trust the tape), applied a strong silicon sealant through the perimeter and contact areas. It works great holding the splitter firmly and securing the front, top and side edges from water, snow and dirt.
Bottom side of the splitter is 1/2 inch deeper than the screen and it is open backwards so it can breath and dry.
Conclusion: 4 existing bolts + silicon sealant. Splitter sits perfectly and firmly for 2 years of all-weather.
Size:  66.3 KB Name:  8aa6914s-960.jpg
      02-20-2016, 05:51 AM   #13
Alcenos
Field Marshal 🔱
Alcenos's Avatar
I'm rethinking my approach to vinyl wrapping my splitter as I cannot find the right amount of material. The 1 foot wide roll is the perfect width, but I can only find it in a maximum length of 5 feet which will not be enough. Any of the larger rolls will leve me with too much excess material.
Any idea on what it will cost me to have it sanded, primed and painted?
      02-20-2016, 05:33 PM   #14
jooobi3
jooobi3's Avatar
Drives: 2011 BMW 535i XDrive
It doesn't hurt to have another 5 feet in extra length to be honest. Room for error which most likely will happen if this is your first time wrapping. Plus if you don't make any error you could possibly use it for interior trims if you wanted too. Regardless I would go with vinyl because it is a lot cheaper than painting it.
      05-20-2016, 05:54 PM   #15
Alcenos
Field Marshal 🔱
Alcenos's Avatar
Just an update. The vinyl wrap attempt was an epic fail for me. I was a bit overconfident based on some smaller pieces that I wrapped. Next attempt will be to paint it.
      06-26-2016, 07:30 PM   #16
Alcenos
Field Marshal 🔱
Alcenos's Avatar
Finally installed and passed the 100 mph highway test.
      06-26-2016, 09:59 PM   #17
lsturbointeg
