2010 2011 BMW 5 Series Forum F10 ► APEX | SM-10 Lightweight Track Wheels |
05-04-2017, 06:11 PM | #1 |
Rep 2,650
Introducing the all-new APEX SM-10 The all-new APEX SM-10 combines a straight 10-spoke design with our “I-beam” milling technique to produce a lightweight wheel that is a departure from our traditional mesh styles. Multiple face profiles continue to provide unmatched big brake clearance. The new milling feature has increased strength while shedding weight vs it’s predecessors, and it adds a visual feature typically only found on the most expensive race wheels available on the market today. Visit our website to order The New Stuff 1. “I-Beam” Spokes This is the most significant new feature we’ve added. Weight is reduced by CNC machining material out from the sides of each spoke. It’s expensive and avoided by almost every manufacturer, but we’ve made it affordable through volume production. 2. Factory Support Like all our APEX wheels, The SM-10 supports all OEM hardware like OEM Roundel center caps, wheel lugs, valve stems, and TPMS sensors. No centering rings are needed either. 3. Beefier Lips By saving weight elsewhere, we’ve added extra material where it counts. We beefed up the barrel’s inner lip to better handle the abuse from the street and track. 4. Concavity Multiple face profiles are utilized to maximize spoke concavity and reduce weight on the SM-10 design. To maintain our great brake clearance the profiles and spoke curvature of this wheel is just like our EC-7 design. Designed for the Performance Enthusiast Light-weight Flow-forming allows for a significant reduction in rotational mass by reducing barrel weight. This manufacturing technique allows our wheels to be almost as light as a traditional forged wheel, but without the significant increase in price. Strength Track duty requires a wheel that can handle the punishment of high lateral G’s, hitting berms, and every once in a while, a small off track excursion. Spoke and barrel design are a major factor in wheel strength. The flow-forming technique uses high pressure disks/rollers to roll the wheel’s barrel into its final shape. This gives the barrel the same strength properties as a forged wheel, since monoblock wheels go through a similar step to form their barrels. We design our spoke dimensions to help evenly distribute loads from the barrel to the center of the wheel. The lack of a front lip, and spokes directly connecting to the edge of the wheel, also add increased strength to the outer lip of the wheel. Chassis-Specific Fitments Stretched rubber, narrow tires, and fender rubbing are not elements to look for in a competitive wheel/tire setup. All of our wheels were designed with offsets that allow for proper fitment of extreme summer, and r-compound tires without the need for spacers or fender rolling. This means keeping the tire under the fender, and away from suspension components. Track oriented wheel widths are also important as they provide proper sidewall support under hard cornering. Too much rubber for a wheel results in excessive sidewall deflection, which translates into sloppy and delayed turning response. Multiple Fitment Options Most BMWs come with a staggered setup from the factory. Some choose to keep their car this way, while others like to switch out for an easy-to-rotate, square/neutral setup. This is generally based on driver’s preference and consideration of tire costs. Most BMW chassis benefit from being able to fit both square and staggered setups with relative ease. 9.5” or 10”-wide square setups are great for budget minded enthusiasts who want to extend their tires life by rotating between events, in addition to preferring the feel of a square setup. Square setups are popular on all models for track use due to the significant increase in front grip and turn-in response. Some owners comment that due to the extra power of their cars, a square setup will lean towards oversteer. For those who prefer more rubber in the rear, a staggered setup is the way to go. Wheels up to 11" wide are available for rear fitment. These can be combined with 9.5” or 10” fronts for a bolt-on spacer-free staggered setup. BBK Clearance Many owners install Big Brake kits on their cars. Having a smaller-diameter wheel that can clear large calipers is a must. Due to the low-offset nature of many BMWs, there are no clearance issues with the concave spokes. Barrel clearance was increased during the design phase to accommodate both StopTech and Brembo's 380mm kit. The APEX Standard 1. FEA Optimization We took more time than ever before on this step, revising and iterating our design to reduce weight as much as possible. After countless iterations we removed material from the sides of the spokes in a way that allowed us to increase strength over our previous designs. 2. Always Flow Formed All APEX wheels feature Flow-Formed construction that utilizes rotary forging to produce a strong and lightweight barrel. The SM-10 is no exception. 3. True JWL & VIA Certification Strength needs to be certified. Our wheels were not simply FEA tested in a computer simulation, or in-house tested to an unregulated standard. We conduct real-world crush-testing and all of our wheels conform to Japan’s JWL standard, as well as being 3rd-party tested by the VIA. All of our wheels carry a 690KG load rating. Available Finishes Sizes, Weights, and Pricing
Questions about tires, fenders, brakes, spacers, or suspension clearances? Click here to get a personalized fitment recommendation from one of our experts. Face Profiles On-Car Photos & Renders Check out our extensive collection of photos on our Flickr page. See more photos >>> Tire Mounting and Balancing Service Popular street and track tires are now available when you order APEX wheels. Add tires with your wheel order and get free tire mounting and balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse. With our competitive tire pricing bundled with the savings of free mounting and balancing and convenience, it’s the ultimate wheel & tire package. *Note: Tires will only ship mounted to the wheels in your order, and can not be sold separately. Tires and wheels must be purchased in the same transaction. Tire-only orders will be cancelled and refunded. Available Tire Brands:
Ordering and Contact Information
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 09-01-2017 at 03:09 PM.. |
05-08-2017, 05:48 PM | #2 |
Rep 2,650
Our new SM-10 wheels are available for pre-order and we are offering enthusiasts Free Shipping on a set of wheels for the rest of May. Check them out on our website here!
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
05-11-2017, 12:59 PM | #3 |
Rep 2,650
We love the 10-spoke design featured on our new SM-10 wheels! Pre-Order today and be one of the first to run these wheels on your car
05-23-2017, 07:31 PM | #4 |
Rep 2,650
What do you think about the new side-milled spokes on our SM-10 wheels? We sure do love them
05-31-2017, 01:38 PM | #5 |
Rep 2,650
The new SM-10 wheels are scheduled for a June 2017 delivery! Pre-order today and be first to get your hands on a set of our new wheels!
06-05-2017, 04:52 PM | #6 |
Rep 2,650
Most of our SM-10 wheels will be in stock this week, with remaining fitments arriving next week! We can't wait to see these wheels on your car!
06-07-2017, 05:00 PM | #7 |
Rep 2,650
A good portion of our new wheels have arrived today! Orders will begin shipping out this week, with the remaining wheels arriving next week
06-08-2017, 05:01 PM | #8 |
Rep 2,650
Check out our SM-10 wheels in the Satin Black finish! We have many sizes in stock and ready to ship. Remaining sizes will be in stock next week
07-10-2017, 06:39 PM | #9 |
Rep 2,650
Here are some on-car pictures of the SM-10 wheels on a F80 M3! Wheels are in stock and ready to ship out! Place your order today
07-13-2017, 06:23 PM | #10 |
Rep 2,650
SM-10 wheels are in stock and ready to ship! Order your set today!
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 08-14-2017 at 05:17 PM.. |
07-17-2017, 05:59 PM | #11 |
Rep 2,650
We love the look of our new SM-10 wheels on this E92 335i! Wheels are in stock and ready to ship
07-31-2017, 04:06 PM | #12 |
Rep 2,650
We're starting to see these on more and more customer cars. Nothing but positive feedback so far.
Here's an E92 M3 with 18x10" ET25 SM-10 wheels all around with 275/35-18 tires:
08-07-2017, 06:52 PM | #14 |
Rep 2,650
We're here to answer all your questions about brake or suspension clearances as well.
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 08-16-2017 at 04:52 PM.. |
08-16-2017, 04:54 PM | #15 |
Rep 2,650
Our SM-10 wheels look stunning in this Anthracite finish.
08-18-2017, 02:51 PM | #16 |
Rep 2,650
A nice side profile showing the face of the new SM-10 wheels.
08-30-2017, 06:11 PM | #17 |
Rep 2,650
Give us a call or PM if you have any questions about sizing, finishes, or brake/suspension clearances.
09-05-2017, 06:42 PM | #18 |
Rep 6,703
This Oxford Green M3 looks killer on Anthracite SM-10 Wheels!
02-22-2018, 04:04 PM | #19 |
Rep 2,650
TIRES NOW AVAILABLE
Add tires to your SM-10 wheels with free in-house professional mounting, balancing, and quality control inspection. Check out our tire selection and feel free to contact us for a recommendation.
05-29-2018, 03:18 PM | #20 |
Rep 2,650
Now available due to popular demand, red APEX centercaps! Use this link to check them out and place a pre-order.
10-29-2018, 05:45 PM | #21 |
Rep 2,650
All BFGoodrich Rival and R1S tires are now discounted when ordered with our wheels. Check our website for current inventory and pricing: https://www.apexraceparts.com/tires.html
04-16-2019, 03:23 PM | #22 |
Rep 2,650
19" SM-10 wheels are now available!
Here's how they look on an E90 M3: Front & Rear: 19x10" ET25 with 275/30-19 tires Spacers: 12mm rear
