2010 2011 BMW 5 Series Forum F10 Slight Vibration at Highway Speeds |
07-05-2012, 02:54 PM | #1 |
Rep 937
OK, I thought I had this issue resolved, but I still have it. I have Avant Garde 19" wheels (hub bore 72.56mm, same as stock) and initially had Continental DWS tires. The setup was never really smooth and I as felt some slight vibration around 70mph. I had the tires Road Force Balanced several times by Discount Tire (where I bought the wheels and tires) and 2 other shops. Each time I the shops would make very minor adjustments (less than a half of an ounce) to one of the wheels, yet the vibration would never completely go away.
Finally Discount Tire decided that the Continentals were just not a good match for the car and gave me full credit toward a set of Michelin Pilot Super Sports even though my tires were nearly 10 months old. The Michelins definitely are a better tire, but there is still a slight vibration around 70mph. Since I never really drove the car much before putting on the 19" wheels, I don't really know if the problem is with the wheels and tires and not the car. I guess I should take the car into the dealer and see if they can locate the issue but I have read many similar posts about vibration and was wondering if anyone found a source of the vibration that wasn't in the wheels and tires. |
07-05-2012, 06:51 PM | #2 |
Rep 4,047
My 528 has had a vibration between 70-75 mph from day one. Slight but still annoying...
07-06-2012, 02:54 AM | #3 |
Rep 48
I had the exact same issue, they changed the break discs, and centrum hub.... car is perfect after that.... they were of by 0,3-0,5mm in the center, made small vibrations....
07-06-2012, 08:14 AM | #4 |
Rep 8,806
If they verified that the wheels are not bent at all on the balance machine then its safe to say its the car. I would def. swap back in the stock wheels and take it in to the dealer.
Alan
07-06-2012, 08:24 AM | #5 |
Rep 937
My dealer swapped out my wheels a couple of months ago when I took my car in for the Pulling to the Right issue. They typically remove aftermarket wheels and temporarily install the OEM ones as a troubleshooting tool. I was impressed that they didn't just try to blaim the aftermarket wheels/tires. Hopefully I'll have the same experience this time around as I am taking the car in either tomorrow or Monday.
07-06-2012, 08:28 AM | #6 |
Rep 8,806
^^ that is exceptional service by a dealer. Most of them would blame the aftermarket stuff right off the bat and not even bother troubleshooting.
07-06-2012, 10:36 AM | #7 |
Rep 308
As an aside (but important) - I would be careful bringing a car with non-runflats into the dealer.
My dealer is adamant (that's not even a strong enough word) about not deviating from stock configuration. My dealer wouldn't touch a car with PSS's (hence my initial hesitation before spending $1100 on two bubbled tires). |
07-06-2012, 12:14 PM | #8 |
Rep 937
My dealer never said a work about the non run flat tires when I took my car in for the Pulling to the Right problem. All they said was that they noticed the problem, put a set of OEM tires and wheels on it and still noticed the problem, then continued to fix the problem. Hopefully they will do the same again.
08-14-2012, 03:41 PM | #11 |
Rep 937
ptyboy25, you have vibration with the M5 replicas that you didn't have with the OEMs. I would check the hub bore on your replicas. The OEM spec is 72.56mm. Many wheels have the larger 74.1mm hub bore which requires hub rings to prevent the vibration.
08-14-2012, 03:59 PM | #12 | |
Rep 55
