2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes BMW M5 to F10 DIY Brembo Brake conversion
      08-01-2017, 06:19 PM   #45
spyroz
spyroz's Avatar
Drives: BMW f10 550i ///M Sport
shhhhh...
Originally Posted by mikekilpatrick View Post
All of my research points to the M5 and f10 using an interchangeable master cylinder. The caliper adapters from Russia are TOP NOTCH and at 440.00 for a front and rear set, a real deal. He even includes the bolts. Torque Specs on Caliper adapter bracket: М12-1.75 torque 115 Nm (~80 ft lbs),
Brembo does NOT MAKE A F10 retrofit kit for the our cars. I spoke to their engineers directly. That means all these kits you see online for brembo f10 calipers are someone taking either m5 calipers or GT calipers, custom making the bracket adapter and making a 4 thousand dollar profit!!! Not one of those kits states a new master cylinder is needed. Even DINAN makes a brembo brake kit for the f10. So.... Where are all of these calipers coming from??? My opinion is they are m5 calipers, repainted, new adapter bracket and then sold at crazy profit.... We will see....
I've send you several PM on this seller, but i never get any respond. I guess either you don't want to share it with everyone or you're just too stingy... either way, good luck with your build man. I'm on the market for a F/R brackets as well.
BMW f10 550i Msport
      08-07-2017, 12:06 PM   #46
mikekilpatrick
mikekilpatrick's Avatar
First Page has the URL's for seller. And in that link the email contact is listed. The email is: Николай Троценко <tronik75@gmail.com>
I have sent the URL, which has the email address in it, several times. This information is in my posts as well. The gentleman is in Russia I believe so you may have to do a google translate. If someone does not want to go to the URL and look up the Email it is: Николай Троценко <tronik75@gmail.com>
      08-08-2017, 03:02 PM   #47
tro-nik
Russia
42
Drives: 120d
Yeah
it's me
we make different adapters for BMW, MB. it's our work
      10-03-2017, 08:26 AM   #48
mr0300
Drives: 535i f10
Originally Posted by tro-nik View Post
Yeah
it's me
Just bought my front calipers and discs,
I read somewhere you also now make adaptors for "stock rear calipers" to take the m5 rear bigger rotors is that right??
will be contacting you by email shortly thanks.
      12-16-2017, 08:01 AM   #49
tro-nik
Russia
42
Drives: 120d
it's too late
but, yes, we make it
      02-02-2018, 01:10 PM   #50
GT-M
Drives: GT 535i Xdrive
I'd like to do this for my 2010 F07 550ix, how would it be different than installing the M5 brakes on a F10, especially for the rear.
Thanks in advance fellas.
      05-07-2018, 11:10 PM   #51
f10_will
f10_will's Avatar
Drives: F10 535 msport xdrive
I got mines done today.
      05-21-2018, 12:52 PM   #52
f10_will
f10_will's Avatar
Ok, so I take it you purchased the axle adapters and then bolted these on? What challenges did you have installing them? How long did it take? Any advice to other members so they can learn from this thread.
Mine are going on in a few weeks. Had to finish up Band and Oulfsen retrofit first and then onto brakes.
Yes I purchased the adapters from Tronik. The install was straight forward, it bolts right on. The only thing you have to cut a little is the brake dust shield to make clearance for the calipers. The install took all day.
      06-08-2018, 06:23 PM   #53
M335
M335's Avatar
47
Drives: E90 n55 IG@FrozenF10
Same here ☺️
      06-09-2018, 09:11 AM   #54
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Looks great!
      09-05-2018, 11:43 AM   #55
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Originally Posted by M335 View Post
Same here ☺️
I see M5 fenders
      09-06-2018, 01:30 AM   #56
mikekilpatrick
Pics of Install
Bump to top to show install pics. I will document everything and post here. There is a considerable amount of prep work to make sure you have all the right parts ready. You will need M5 Brake lines front and back, Rear M5 Brake line clilps, Front Rotor Bolts to hold to axle, have a dremel ready to cut the brake dust protectors, have a 9 MM HEX socket ready as most sets only have a 8mm and 10 mm in them, and a few other little tips and tricks. Also highly recommend a pressurized bleeding system so one person can bleed brakes.
      09-08-2018, 04:12 PM   #57
mikekilpatrick
Rear adapter clearance issue
So, it looks like the rear adapter brackets are off 2-3 mm on my car. Did anyone else have issues mounting the rear adapters? I thought at first I might have had the wrong bolts cause the body shop lost my original M12 1.5 x35mm bolts. But it looks like this is an issue with the start bolt.
The top star bolt that inserts from the car side into the Brake pad assembly will not clear the axle mount.
This was fixed by removing 2-3 mm of material from the axle with a Dremel. Just make sure you dont go into the Mounting bolt mounting face. Then ensure you smooth off cut to prevent a cracking surface.
      05-14-2019, 10:09 AM   #58
mikekilpatrick
Bump for those doing this now
      06-16-2019, 05:00 PM   #59
ki_soarer
Drives: 2010 335D
Hi gents. I don't venture into the 5series forum often, but I have a set of blue front M5 calipers if anyone is looking. They should be rebuilt as at least one of the seals is leaking, but I have not had time to mess with them. I have seen full rebuild kits for both calipers for $500 including new pistons. PM me with an offer if anyone is interested. If not, I may save them for when I pick up an F10 of my own.
      06-17-2019, 09:45 AM   #60
Luky
Luky's Avatar
Drives: 2016 550i M Sport
Just read through the thread. It talked about the rears being 4 piston calipers, but pic above shows standard 1 piston? Skipped the brembo rear? I was wondering if there was a brembo rear that worked with the electronic parking brake on the f10 (does M5 rear have electronic parking brake too?) I have a stoptech bbk in the front, and would consider an upgrade for the rear if available...
      06-17-2019, 12:48 PM   #61
mikekilpatrick
One Piston Rear brakes, any mention of 4 piston was a typo. The rear Caliper IS IDENTICAL to the M5. The only difference is the rear brake pad assembly. Thought I mentioned that somewhere. You could use your existing caliper and add the Brake housing holder if you can find the part. Of course it would need to be painted blue. You will still need adapter to move the Caliper housing away from Hub to accommodate the bigger rotor though. You can also purchase OEM adapter from Person mentioned earlier in this thread and use existing caliper and brake housings and the adapter will mover the assembly to proper distance. And yes, M5 and non M5 all use Electronic brake.
      02-07-2020, 06:43 PM   #62
Drlgrg
Drives: BMW 550i 2014
I have a BMW 550i F10 2014 and I have found a Porsche Cayenne 2006 front brembo Z18 caliper for a very good price. Anyone know how I can fit them in my car or any kit or adapters available
      02-09-2020, 11:07 PM   #63
BimmerHausPerformance
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
This looks interesting. What was your all in cost mike?
      03-03-2020, 03:00 PM   #64
mikekilpatrick
Probably about 2000.00. I got the calipers and pads/rotors on the cheap, then had them repainted, then the adapters. Been on the car for about a year with no issues.
      06-13-2021, 10:58 PM   #65
kelson teh
Drives: bmw f10 535i
hi
im interested. may i know more about it ? photo maybe.
      06-13-2021, 11:01 PM   #66
kelson teh
hi all... amazing work guys, i just got my 535i about 9 month,
done installing brembo 19z on my car, but i feel the brake is way more softer than the original, if the master cylinder is help, any chance i can have the part number so i could find it and replace. or is the 19z make the brake feel soft???appreciate it...
