2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Escort 9500ix Hardwired in F10
      07-16-2014, 04:33 PM   #1
virtualbong
virtualbong's Avatar
103
Drives: 2015 BMW X5 MSport
I just completed this DIY yesterday. So happy not to have the damn power adapter wire dangling all over the place.
I used the F10 V1 Hardwire Video as well as this DIY guide below.
I used the video for a nicer reference guide but the only difference from the video is that I did not use the bolt to get ground. I used the tutorial below and tapped the wire leading to the sunroof.
Here is the DIY Guide:
http://www.bimmerfest.com/forums/sho...d.php?t=515517
Here are some pics of my setup:
The radar detector is installed on the mirror using the Blend Mount device.
I installed the SmartCord on the upper left hand side so that it is easy to reach and out of the way. I used the double sided velcro tape to mount it. If anyone is concerned about the flashing LEDs, you can flip the visor down which will block it from any po po behind you. Looks great imo.
Here is what the total setup looks like:
The only issue I ran into was that the tap to get the power was not perfect so I had to tap the wire again. It still was not perfect but I put the cover back on and it has been working fine every single time <crossing fingers>
Let me know if anyone has any questions.
btw. the green/brown wire was not shiny like the pics and video. Same goes for the ground wire in the back.
WIL
2015 BMW X5 35i M-Sport (White/Brown) - 4/16/18 (Current)
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST
| 1998 Acura Integra (Black/Black) - PAST
      07-17-2014, 11:39 AM   #2
obiltagi3
V.I.P.
obiltagi3's Avatar
Drives: F10 535i 2011, F10 550i 2015
2015 BMW 550i  [9.00]
Excellent step by step DIY.
Thanks for supporting the community !
F10 550i Imperial Blue/Ivory
BM3 Stage 1 - xHP Stage 1
F10 535i Alpine White/Oyster
BMC - Vorsteiner Exhaust - ER Chargepipe - AR Catless DP - MHD Stage 2 - FMIC
      09-23-2014, 10:09 PM   #3
yogi
Ninjapotamus
yogi's Avatar
Drives: F10 & E90
@virtualbong, i just ordered my 9500ix. does the hardwire cable and the smartcord come with the detector? or did you gave to but it separately?
also, just wondering. is there any reason i cant use some velcro or double sided tape and mount the detector to the top of the mirror? seems like a pretty good spot for it and more out of the way.
      09-24-2014, 08:11 PM   #4
virtualbong
103
You have to purchase it separately.
You can definitely do that but I didn't want the tinted part of the windshield to diminish the strength of the detection. I would do a test run first to make sure the detection is still strong. If it works, the 3M double sided velcro is strong enough to keep it in place up there. Take some pics if you end up going that direction.
      09-25-2014, 01:04 PM   #5
yogi
Ninjapotamus
yogi's Avatar
Drives: F10 & E90
thanks. i'll post up in a couple weeks when it's done.
