2010 2011 BMW 5 Series Forum F10 low fuel pressure need help n55 |
08-19-2023, 07:43 PM | #1 |
Rep 100
Hey guys so I’m having a bit of a issue with my fueling in my 2011 535i and I’m getting shadow codes for having low pressure in my high pressure. I’m getting two codes I will show in a picture. My symptoms as of right now is just a long crank when car is cold. But if I drive for a little and start it up again it will start right up and drive no issues. There are no misfires or anything and the car still pulls. I am not tuned. I already replaced my high pressure fuel sensor on the rail. Would I need to reset adaptations or anything in that sort ? Any help would be appreciated.
08-20-2023, 12:34 PM | #3 |
Rep 100
Ughhhh I really don’t want to have to do that but if I must I will. I feel like I’d have more issues if it were the pump tbh
08-21-2023, 09:11 PM | #4 |
Rep 553
Those early N55s still used the same HPFP as the N54 which were known for failing, so there’s a good chance that could be it. I know you’re not tuned, but if you were you could log the fuel pressure under boost and see if it’s dropping.
08-24-2023, 10:35 PM | #5 | |
Rep 658
Also, do you have any mods (being tuned is software, you can have mods and not be tuned so I have to ask lol)? I only ask because those shadow codes are exactly what people that are on their first revision of an upgraded HPFP get (this gets tuned out in the later revisions as sensor operating ranges get expanded so as to not trip the codes). I know this because I have these same shadow codes and long cold cranks after having installed a Helix Overdrive. I am still on the first revision as well so this is expected.
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
09-02-2023, 10:00 PM | #6 | |
Rep 100
