2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications BMW M5 intake installation
      09-05-2023, 11:46 AM   #1
slobo7x
Drives: 2016 550 F10
So I finally have some time to start working on my M5 factory intake retrofit this weekend.
I realize there are a few aftermarket choices, but I'm trying to keep the engine bay factory looking while possibly getting some performance out of the air intake system. I believe the factory M5 intake system should yield some increased air flow due to the less restrictive pipe design.
There is a thread below of a guy doing a custom setup with chevy MAF adapter, which brings me to my question..
Can I use the M5 MAF sensors, since the mounting points for my N63TU MAF's are different then the intake hoses from the M5? I have a stage 1 BM3 tune, was just worried about installing the MAF from a slightly different engine management system.
Anyone have any thoughts on combability?
      09-10-2023, 04:46 PM   #2
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
I don't believe the M5 has MAF sensors. So there is no compatibility.
The S63/TU removed the MAF sensors and used a different method to derive airflow. BMW realized that MAF sensors reduce airflow by about 28% (from memory). So they derived MAF by other means.
Which means a tune for you to run MAFless or retrofit in the N63TU MAF sensors with some tubing or something else.
      09-10-2023, 07:33 PM   #3
slobo7x
It has maf in the air intake housing pipe, just like my n63TU, the plug is the same and all but I don’t know if software wise in DME it’s not utilized.. if it isn’t then I should be ok then.
Thanks
      09-11-2023, 03:30 PM   #4
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
You're thinking about the F90 S63. The F10's S63 still used MAF sensors.
2015 BMW 535xi
ISTA VM Setup/Tutorial
