2010 2011 BMW 5 Series Forum F10 Close to purchasing a n63tu vehicle. Want advice |
09-01-2019, 09:10 AM | #1 |
Rep 30
Hello I'm currently in the process to get a car with a n63tu engine and I'm wondering how reliable the n63tu is. We have 2 n54 cars in the fam so I'm famliar I guess with the bmw problems that occur. I'm kinda nervous after reading a few forms and idk how to feel anymore and I'm tryna just get some input. Thank you!(14 550i 59k Miles. Sold by bmw, one owner and 2 service records first one at 39k miles regular maintenance. maintenance by bmw. Build date "10/13")
Hit me with all the info! Would like owners with N63tu to give a brief guidance about their ownership with their N63tu |
09-01-2019, 12:46 PM | #2 |
Rep 136
I was in the same boat as you having come from a BMW V8 (650), I was hoping the TU V8 would save my dream of buying a 550 after hearing all the problems with the 2011-2013 models. Sadly it looks like even the TU's are risky to get involved with. I believe the TU's are now apart of the class action engine replacement lawsuit (550,650,750). IMO it's just too risky of an investment.
https://f10.5post.com/forums/showthr...ighlight=N63tu Last edited by bigscore; 10-15-2019 at 07:42 PM.. |
09-01-2019, 12:52 PM | #3 | |
Rep 30
09-01-2019, 10:40 PM | #5 |
Rep 1,299
I would advise against going with V8 from BMW. My brother works at the dealership and he sees plenty of 550s come in for services, engine removed to fix issues. Even the new m550s have issues and had an engine replaced within 6k miles. I would avoid it if I were you unless you going to get aftermarket warranty with it and plan on selling it as soon as the warranty runs out. Which also means forget about tuning it if you plan to do that.
In my opinion inline 6 are best motors to own after warranty runs out and V8 are the ones you want to lease so you are covered under warranty. |
bigscore67.50 |
09-02-2019, 12:34 PM | #6 |
Rep 136
Also keep in mind that in the unfortunate event that your V8 qualifies for a motor replacement down the line, you still have to wait on a waiting list for the replacement motor and you still have to pay a couple of grand in labor fees.
09-08-2019, 03:09 PM | #7 |
Rep 1,649
The answer to your question is DONT DO IT! I've had nothing problems on the past N63 engines! Just look at the Service Bulletin list that BMW has developed. Numerous issues from top to bottom. HPFP, Injectors, burns oil excessively (every 500 miles to off).
Today...sport mode...hard acceleration... DRIVETRAIN MALFUNCTION!! Going to my tech again to see what coils went bad this time. Or is it the Injectors. Or is it something else. |
09-08-2019, 06:45 PM | #8 | |
Rep 5,365
09-09-2019, 06:48 AM | #10 |
Rep 276
N63TU here in an F15. 91k miles. Dealer serviced, I do oil changes every 6k or so and never have to add oil between changes. BM3 tuned for the last 12k miles, runs 11.7 int he 1/4. No issues so far, but we will see!
09-12-2019, 05:04 AM | #11 | |
Rep 1,649
10-12-2019, 04:48 AM | #12 |
Rep 32
What did you get? I was in same boat trying to figure out which way to go.....decided to go with a little more reliable N55 and tune it a bit. Hear all kinds of horror stories about n63....it comes down to maintenance and how much money and time you want to invest to keep the hot v8 running well......if you can get a warranty that will actually take care of the issues it would be ideal....but it is interesting how many aftermarket warranties will not warrant the n63 cars!
bigscore67.50 |
10-13-2019, 04:09 PM | #13 | |
Rep 1,649
So I'm pissed now...run this by my dealership. Told them what I replaced and I want a reimbursement since this part is on the extended warranty list. He said no because they didn't run the scan and diagnose the car. I said F of course and called BMW relations and told them and she said pretty much the same thing but to send in the invoice anyway to see if possibly they could do something. Third time a charm, NO! IT gets better. 2 weeks later, drivetrain malfunction light comes on but it's driveable. Now I'm getting smart right...take it to my tech to run the scan. He says HPFP bank 1. This pump is on the passenger side. Definitely warranty right? BWM tech can't find the code about the HPFP taking a crap. No fix. THey instead replaced a Rail Pressure Sensor harness. Asked me if ran crappy on a low tank of gas. NO! $400 later I get my car back. In summary... WTF! I'm going to limp through another year or so I can and then dump since my aftermarket warranty runs out and basically not helping yet on my case. It's frustrating when something just doesn't work out that way you expect it huh? LIFE 101!!! Get used to it. |
10-14-2019, 05:14 AM | #14 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
The forums can be a bit of an echo chamber for people reporting problems/looking for solutions. Most folks who drive the car and go about their daily business without problems aren't here.
So I'm going to chime in with a bit of counter point. I own currently two BMW v8's an S63 (2011 X5M) and a N63TU (2016 550i). Neither engine has catastrophically failed, both are running fine, no smoking, and maintained their power unlike the ecoboost fords.... https://www.caranddriver.com/reviews...y-maintenance/ I have 65K miles on the 550i, and only had a few minor issues with the car. Bad 02 sensor, and a bad charcoal canister valve. The 550i doesn't leak oil, it doesn't smoke, it runs every day, drove it from Houston to banff (canada) and back, never broke down or had any real issues. I'm a second owner, and change the oil every 6-7K miles (usually on a dealer $49 special). My advice is that the BMW v8's are expensive engines, mainly because their failure points are in very inaccessible areas of the engine that take multiple hours to get to. Also BMW had crappy engine bay plastics in all of their cars (inline 6's included) and in houston, everything in the engine bays on all of my BMWs turn to crap after about 6-8 years, regardless of the engines. Yes even my 335D suffered cracked PCV lines, vacuum lines, sensors breaking etc. So these car's with their embrittlement prone plastics, engine seals (oil leaks) that fail quickly, getting an extended warranty for piece of mind is a good idea. I have on on both my cars. But these problems seem to plague nearly all modern cars (even honda's). Though I do notice my wife's 2013 mini has no problems with plastic embrittlement....... Also watch out for vibration problems with F10's this is another common issue. Last edited by Thecastle; 10-14-2019 at 05:24 AM.. |
Krism57.00 SummerallGuard0483.50 |
10-14-2019, 12:06 PM | #15 |
Rep 5,365
Does it burn oil? Add any between changes? That is one of the big N63(TU) complaints. Not like the rod bearing failures of the M5 V10.
10-14-2019, 01:34 PM | #16 |
Rep 1,649
10-14-2019, 02:54 PM | #17 | |
Rep 1,146
Drives: F10 550i
I've had 3 BMW V8s, a N62 4.8i which did burn oil at a rate of about 1 qt every 3-4k, but it had bad valve stem seals and sold it with about 98k miles. It was my batmobile until it chugged some AT-205 which stopped it from smoking. The N62/S63 have both had lots of oil leaks, S63 valve covers have been replaced, rear main seal, oil pan gasket, turbo oil lines, turbo oil line return block, whole PCV system. I do run ceratec in both cars. |
10-14-2019, 09:45 PM | #18 |
Rep 32
I’m just glad I didn’t get he c7s4..... 2 out of 2 I looked at and did due diligence on had their turbos recently replaced....that was a big ticket item. The one main reason that scared me off was injector replacement was an engine out process to be done correctly...ouch, and Mechatronic issues. Liking my 3rd n54/55 buy.
10-21-2019, 07:42 AM | #19 | |
Rep 75
10-28-2019, 09:36 AM | #20 |
Rep 2,416
i say go for it, i owned 2 cars both with N63 motors my current one being 2011 with 109k miles pushing 650whp 690wtq and so far has no issues and i drive her hard daily.
You should do preventative measures as soon as you get the car to prolong the engines life. ( oil cooler valve, low temp thermostat, use liqui moly oil with 2020 oil saver, N20 coils). As mentioned previously this is an echo chamber and most people come with complaints issues to forums. Links to products: Liqui Moly oil: https://amzn.to/2Wl2WtP Liqui Moly oil saver: https://amzn.to/32VtdkX oil cooler valve: https://n63intake.com/product/n63-n6...-cooler-valve/ low temp thermostat: https://n63intake.com/product/low-te...s63-s63tu-s55/ |
11-02-2019, 10:56 AM | #22 | |
Rep 342
I found ecs sells a low temp 90C thermostat kit with new temp sensor and some coolant for $132... https://www.ecstuning.com/b-assemble...BoCpWkQAvD_BwE Last edited by Luky; 11-02-2019 at 11:04 AM.. |
1stock5501.50 |
