2010 2011 BMW 5 Series Forum F10 Close to purchasing a n63tu vehicle. Want advice |
11-05-2019, 04:30 AM | #23 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
Can’t see why it would hurt to open the hood. It’s a combination of heat and time that drives out the elastomers (softeners) that cause the plastics to loose their pliability and embrittle. It probably makes more of a difference in the summer.
11-05-2019, 04:46 AM | #24 | |
Rep 1,146
Drives: F10 550i
Anyway most of these aftermarket recalibrated low temp thermostats are set at 95c (they advertise 90c) for full open. The reason being is many bmws will throw an error and a check engine light if they stay at 90c. Some are actually 90c supposedly the Hamburg tech ones but you risk throwing a code for low coolant temp. For reference I’ve installed one on a n62 that I purchased from eBay. Before install the engine ran at 105-108c. After install it was 98-100c. So it makes a difference but it won’t be a 15 degree drop like they advertise. With that said I plan to do this mod on my x5m and 550i. It will lower the fuel economy but hopefully lower repair bills offset the cost of fuel. Fuel economy drops because of more combustion heat transfer to the cylinder walls instead of driving the piston down. In general gasoline engines run most efficiently at around 110c. But lower temps make more power. |
02-15-2020, 09:55 PM | #28 |
Rep 5,365
Hope you're not trying to fool Kommiefornya's emissions Nazi's. I got a failure because I had the wrong CARB sticker for my car (even though the engines were identical in every way save the logo on the engine cover!). They know exactly what to look for and probably every trick; they're trained well.
02-18-2020, 07:33 PM | #30 |
Rep 1,146
Drives: F10 550i
Sure, for emissions component not ready, but not necessarily for an under temp error.
It’s a good question why no tunners command a lower operating temp for these map controlled thermostats. But then again most tunes are Purchased from one source. I did buy a low temp thermostat on my s63 x5m and it sits at 93c now. Last edited by Thecastle; 02-18-2020 at 07:46 PM.. |
02-20-2020, 02:25 PM | #33 |
Rep 133
But if you have emissions test in your state, tune can't help you pass inspection. All they can do is a soft delete, no different than JB4 or BM3 would when clearing the light. And it's a felony for tuners to do anything different.
Just putting this out there, not saying that you're stating the opposite or anything like that! |
04-15-2020, 03:31 AM | #34 | |
Rep 6
Luky77.50 |
08-16-2023, 02:01 AM | #35 | |
Rep 20
I know been a while, hows the x5 been treating you? |
08-16-2023, 10:04 AM | #36 |
Rep 114
i have a '16 550 w/ 23k miles. I change the oil every year or every 6k miles. i would recommend a blackstone oil analysis every few years. they're inexpensive (like $30) and give great peace of mind. I have yet to have any issues with my engine. i am also a very conservative driver, all oem, don't dog it but always appreciate a highway or interstate on/off ramp. i also believe in popping or cracking the hood to let some of that hot air out in the warmer months.
2016 BMW 550i M Sport - Mineral Gray Metallic
2015 BMW X5 base - Jet Black 2011 BMW 335i - Alpine White |
09-09-2023, 10:17 PM | #37 |
Rep 435
Drives: 2016 F10 BMW 535i M Sport
Keep fresh oil in it, keep up with your Maintenance, put good fuel in it, keep up with fluid exchanges and replacements, address issues and make a checklist and do not ignore even small issues especially if it is a leak, and lastly don't go crazy on the engine when cold, (let her warm up to temp before you give it a rip) Please enjoy your N63TU and if you take good care of your Engine and transmission, you will have many, many years of enjoying it. I was very close considering an N63TU! Congrats! Educate yourself as much as possible on your car so you will enjoy it that much more!
